Feature request for spiral "bore" cycle
Don.Cyr
Message 1 of 1
Don.Cyr
In other machining strategies, such as pocketing & contouring if we check the option box for "finish passes" it gives us the option to have the finish pass feedrate differ from what is set on the Tool tab (if this is changed, it will give a pop-up warning). Using the spiral bore strategy, it doesn't give us this option and it would be nice to have vs creating another toolpath for finishing. In this feature, we also aren't given the option to specify "feed height" it feeds to Z0 then begins to spiral into the work, not a big deal, but would e nice to have the option especially since it uses the "lead-in" feedrate and not a separate plunge feedrate.
Screenshot of the 2 options below:
Please click "Accept Solution" if I helped with your question or issue.
Replies (0)
