Feature request: Better options to reduce chip accumulation during drill operations
- Mute
- Permalink
- Report
I spent a good bit of time today drilling some deep holes in PEEK plastic today. It a thermoplastic that creates a stringy messy birds nest of chip accumulation around the drill. For the life of me I could not get it to break a chip.
Haas has an optional variable āEā in the g83 peck drilling cycle that will reverse the drill after the cycle is complete. E5000 should spin the drill in reverse to 5000 rpm. Adding this to the options in the drill cycles would remove stringy chip accumulation with many materials, but with deep holes in peek Iām not sure it would be enough. I ended up pecking to try to reduce the chip accumulation. It helped a bit. I ended up stringing together multiple peck drilling operations with a full retract on Z then stop the spindle and a M00 mandatory stop to give me chance to manually remove chips from the drill bit. Automating process like this would be incredibly helpful. Also giving greater control with G83 peck drilling cycle on how high the peck retraction R value is above the part would be great. Such that it start drilling at the top of the part, but the drill would retract 1ā above the part to clear the chips the rapid back down to where the drill left off in the cycle. If it could optionally spin in reverse when it reaches the retract height that would be fantastic.
