Fanuc turning post processor problems
lethal375
lethal375
Fanuc O
When I select "Use Canned Cycle" G71 the code is never correct?
Have tried type A, B, & C configuration
Most of the problem is with Rapid to position before and after G71 lines
Post processor output that does not work
N22 G0 Z0.005
N23 X0.35
N24 G71 U0.008 R0.01
N25 G71 P26 Q30 U-0.008 W0.004 F0.006
N26 G0 X0.574 Z0.005
Modification that works
N22 G0 X0.35 Z0.005
N23 G71 U0.008 R0.01
N26 G0 X0.574
Am I missing something?
a.laasW8M6T
Hi
I recall there being issues with canned cycles if the compensation for the tool was set to "Tip" rather than "Tip tangent"
You should be using Tip Tangent in most cases anyway
Andrew Laas
Senior Machinist, Scott Automation
lethal375
Just checked and the tool compensation is as you suggested.
CNC_Lee
@lethal375
If the generic posts are not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Please message me if still needing assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
seth.madore
Is the issue that it's posting out X/Z moves on the retract, but separate X/Z moves on the approach?
Seth Madore
lethal375
Not sure exactly what your asking?
Rapid moves before canned cycle are separated in 2 lines?
If combined it works
Just wondering why they are separated and if no one else is having this problem then I must be doing something wrong?
