FANUC Post Processor - Add M code to Unlock/Lock B Axis for Rotation
101Vance
101Vance
Yesterday (with forum help) we were able to get the correct format output of the latest FANUC Post Processor. I'm very thankful to be with the latest. However, the journey isn't over. With my older post processor I was able to edit it so that the B-Axis Unlock/Lock "M62" is added at the end of a B-Axis rotation see attached photos of outputs. With the Latest Fanuc PP, I can't seem to find a good place to add that
Old FANUC postOld FANUC post
(Above is the old FANUC Post Processor)
Updated FANUC postUpdated FANUC post
We need the B Axis Lines to have the M62 code (it handles the Unlock/Lock of the table).
Side Note: Yesterdays edit/fix was to change useTiltedWorkplane to "false".
Any help would be greatly appreciated.
a.laasW8M6T
Hi
In this section of the post you can add the M codes
Are you sure M62 is for lock and unlock?
normally there is a different Mcode to Lock vs unlock
101Vance
Our machine has three states
M61 Unlock - Keep Unlocked
M62 Unlock and Lock after B axis move (This handles both states during a move, simplifies code).
M63 Lock
I've been using the M62 for 99% of the time.
I made the edits and now I'm getting an "mformat not defined".
I'm very grateful for your help with this.
a.laasW8M6T
Hi
you may have a syntax error in your post
see the attached post.
I have removed the Lock command as from your description this is not required
101Vance
This is a winner. Thank you and Kind Regards.
