FANUC Modular G- Code Programming
wgr_eng
Message 1 of 9
wgr_eng
Hello
I was wondering if I could modify the generic Fanuc post to output code in this format.
The generic Fanuc post is of no use. I get a lot of errors when I run in my Hardinge GX 250 5 AX Fanuc 31 I B5 controller.
I stop & run operations from the middle of the program and since the generic post doesn't output safety blocks before each operation I really can't run operations from the middle of the program.
It'll be great if some could help me figure out a working post.
It has been almost 3 months since we purchased Fusion 360 and there is not one part we have made using it.
Replies (8)
Message 2 of 9
KrupalVala
Hi @wgr_eng ,
Instead of G65 P9006 (Activate Features) you want to call a O9006 (Activation Macro) and Instead of G65 P9008 (Deactivate Features)you want to call a O9008 (Deactivation Macro) ?
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 3 of 9
wgr_eng
Hello @KrupalVala
Thank you for getting back.
The generic Fanuc controller doesn't output proper G code. After the end of a multi axis operation I get an improper G code alarm.
So I wanna have my custom macros
I want to do a macro call G65 P9006 to activate all the 5 - axis features.
Then the body of the program with the part geometry.
Before the end of the program or tool change I wanna deactivate all the 5 Axis features using another Macro G65 P9008.
Please review my current sample programs and lemme know if you have any questions.
Thank you
Message 4 of 9
wgr_eng
Hello Krupal
I am using a Fanuc Post Processor for the machine Bridgeport GX 250 5 AX-  with A & C axes Fanuc 31 I controller. The machine does not have a probe so please ignore the Probe Macros.
I couldn't use the generic FANUC post (with so many alarms) so I was thinking if I could use working custom activation & deactivation macros as given in the Fanuc Manual.
But it maybe be a complex logic to build. So I was wondering if you could help me modify the post with the custom changes needed.
Please refer to the nc files attached. I attached 3 NC code files & the project file.
>>> SOLIDCAM FANUC WORKING G CODE
Working G code from SolidCam
>>>FANUC GENERIC POST OUTPUT 1003 - UNEDITED
>>>CHANGES NEEDED 1002 - CHANGES NEEDED COMMENTED
Message 5 of 9
wgr_eng
Basically I am trying to do a manual Force tool change before each operation because I run operations from the middle of the program.  So the changes I needed will be the initial safety commands before a tool change , cancellation after the operation  & retract to safe plane.
Please find the attached PROJECT FILE.
Let me know if you have any further questions
Thank you
Message 6 of 9
KrupalVala
Hi @wgr_eng ,
Thanks for sharing the files. I will work on it.
Krupal Vala
Message 7 of 9
KrupalVala
Hi @wgr_eng ,
I have compared both files and found that some of the options you can activate through post properties and CAM project.
To get G54.1 P1, You need to set  WCS offset more than 5 in CAM project.
To get smoothing codes and G53 safe retract, You can control through post properties.
To output, Q codes instead of P, Search below codes and change it  Q.
// Output each operation as a subprogram
  if (!usePattern && properties.useSubroutines) {
    currentSubprogram = ++lastSubprogram;
    writeBlock(mFormat.format(98), "Q" + oFormat.format(currentSubprogram));
    firstPattern = true;
    subprogramStart(_initialPosition, _abc, false);
to get force G69 at the start of the program, search below codes and codes as shown below,
// absolute coordinates and feed per min
// add these two lines codes from here to
  gRotationModal.reset();
  writeBlock(gRotationModal.format(69));
// here
  writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(properties.useG95 ? 95 : 94), gPlaneModal.format(17), gFormat.format(49), gFormat.format(40), gFormat.format(80));
to get force G0 or G90 with other NC codes, You need reset the codes {___.reset()} and then Add the code(G90 or etc) with other NC codes(X,Y....)
} else {
    gAbsIncModal.reset(); // reset
    gMotionModal.reset();// reset
    writeBlock(
      gMotionModal.format(0),
      conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
      conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
      conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
please note after the modification save the post and then test it carefully. I know there are other minor or same modification required as per the sample file but I think, now you can manage it.
I hope this helps, but please let me know if you need anything else or if you have any questions.
Krupal Vala
Message 8 of 9
wgr_eng
Hello @KrupalVala
Sorry for the late reply. I've been very busy.
So I made those changes and tested the program and I noticed the Euler angles are not correct.
How can I influence these angles to output code as required.
Thank you
Message 9 of 9
KrupalVala
Hi @wgr_eng
In default condition Fanuc work with ZXZ Euler Convention method.
But Based on your requirement/Configuration, You can change the Euler method by changing the ZXZ to any Convention method as shown below Image.
Please refer controller manual before changing the Euler angle it also change the Rotary as well as linear axis direction.
Krupal Vala
