Fanuc mill/turn postprocessor not outputting milling mode M code.
Stevenl89
Stevenl89
I own a Dainichi F20BM lathe with Fanuc 16T control. The lathe has live tooling(not Y axis) and a sub spindle.
I have managed to get a postprocessor for the machine but there is still som problems.
When I try to do a live tooling operation in Fusion 360 I cant get the code to ouput M35 (which is activate milling mode) on the machine before it starts with the live tooling operation. I have activated "live tool" in the tool library in Fusion 360.
It also seems like the code outputs a negative number for the C axis. Is this OK?
Anyone who can help me with this? Please see attached files.
Thanks!
Arun.rs
Hi @Stevenl89
Thanks for raising your concern via Forum.
Could you please share your model file so that I can have look into the same?
File>Export>.F3d save the file and attach the file to this thread.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Stevenl89
Thank you so much for looking at it! File is attached 😊
Arun.rs
HI @Stevenl89
I think you have wrongly assigned the C axis engagement codes.
1. Got to 'function getCode' in post processor. Change as below,
case "ENABLE_C_AXIS":
    machineState.cAxisIsEngaged = true;
    return (spindle == SPINDLE_MAIN) ? 35 : 135;
  case "DISABLE_C_AXIS":
    return (spindle == SPINDLE_MAIN) ? 34 : 134;
I am not sure about the lock codes, I have set M89 for Main and M189 for Sub spindle.
 case "LOCK_MULTI_AXIS":
    return (spindle == SPINDLE_MAIN) ? 89 : 189;
  case "UNLOCK_MULTI_AXIS":
    //return (spindle == SPINDLE_MAIN) ? 36 : 136;
  case "CLAMP_CHUCK":
2. Got to line number 1661 and remove the '//' from below code.
writeBlock(feedMode, gPlaneModal.format(plane), cAxisEngageModal.format(getCode("ENABLE_C_AXIS", getSpindle(PART))));
Save the file and test the NC code carefully.
For detail info about the post editing please refer the  FAQ link
Regards
Arun.RS
