Post processing always fails after update today (5/21/2019). Same post process worked yesterday. Tried the most recent CNCRouterparts config from your site (.cps file), still fails. See Log below (edited out what I thought might be private with XXX's:
Information: Configuration: CNC Router Parts (Mach3Mill)
Information: Vendor: CNC Router Parts
Information: Posting intermediate data to 'J:\My Drive\CNC\CNC Offline\PD1 Test CNC Tripockets Only.tap'
Information: Total number of warnings: 3
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, May 21, 2019 3:42:08 PM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.3.0 45221
Configuration path: c:/users/kmass/appdata/local/autodesk/autodesk fusion 360/XXX/w.login/m/XXX/camposts/cncrouterparts.cps
Include paths: c:/users/kmass/appdata/local/autodesk/autodesk fusion 360/XXX/w.login/m/XXX/camposts
Configuration modification date: Tuesday, May 21, 2019 3:39:39 PM
Output path: J:\My Drive\CNC\CNC Offline\PD1 Test CNC Tripockets Only.tap
Checksum of intermediate NC data: bc59cf7e65f158bdecacb2991615f42d
Checksum of configuration: c60e593bcc4faa0bf00ba8c1d0cd17c8
Vendor url: http://www.cncrouterparts.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.5790
Error: Invalid machine configuration in toolpath.
Error: Failed to execute configuration.
Stop time: Tuesday, May 21, 2019 3:42:08 PM
Post processing failed.
