FAGOR TURNING POST 8055T 8037T
Paul_NextMedicalDesign
This is somewhat of a follow-up to an earlier post I made (I think the link is below....)
https://forums.autodesk.com/t5/computer-aided-machining-cam/issue-with-a-change-to-post-processor/m-...
The short story is that I have a Fagor 8037 TS controller, and the post available from Autodesk for 360 is for another controller, 8055T.  I called Fagor today and the tech there says the programming/syntax for these controllers are the same.  So, Autodesk could add "8037" to the post description, could save some other some time.
There are a few issues with the post that I discovered....and there is a few others that have posts back in late 2016 about the I and K values for the G3 and G4s.....Fagor 8055 and 8037 must have these values (force an I0 or K0 is necessary)....I resolved this issue by using the optional R values in place of the I and Ks....but a fix would be good (refer to my last post, as someone already has the answer that I have yet to try).
Anther bug I found:  for drilling canned cycle G83, the code needs a B value.  B tells the machine whether to tap or drill, but similar to the above, a B is mandatory.  For pecking, it works, for a regular in and out drill, there is no B posted and it is an error.  I correct this manually by making the B (which is the drill step) equal to the overall depth I.  Seems to work, but I did not study closely.
Paul
bob.schultz
Hello Paul,
Thanks for bringing this to our attention.  The next release of the generic Fagor turning post will contain these fixes.
Bob
Bob Schultz
Sr. Post Processor Developer
