Fagor 8065 - Safe Retracts using MSC - Post Processor Output
Jason_KellyU5SST
Message 1 of 1
Jason_KellyU5SST
Hello there,
I have a DMS gantry router that uses a Fagor 8065 controller and I am having issues with my modified post-processor. I need to use MCS for safe retracts and home, but the output does not include a decimal point. Example below.
I've tried editing the post in a few ways but have either gotten errors or the output hasn't included a zero. Pertinent code below.
Changing the value to 0.0 still outputs 0.
I changed the post for "safe z" to:
value : (unit == MM ? 12.0 : 0.5),
This does in fact output with a decimal but doesn't seem like the right way to go about it.
I haven't been able to get "park XY position" to output with a decimal with any configuration.
Any ideas? A coworker had worked on this post a few years back with @bobschulz1  an associated thread is here, but doesn't relate to this specific issue.
Thank you for any help. The post works with G53 in three axis operation, and with standard values for Park XY and safe Z, but we need to adjust these values to return all axes to zero in a safe position. So when we use something like Z-10.0 for safe Z, we get an error because it is looking for MSC. If we leave the values at zero the machine can easily crash.
Full post-processor code is the last block of code below.
https://forums.autodesk.com/t5/fusion-manufacture/cannot-edit-post-w-o-quot-invalid-post-processsor-...
1001
N10 ; T10  D=0.375 CR=0 - FLAT END MILL
N15 #MCS OFF
N20 #CS OFF
N25 #RTCP OFF
N30 #HSC OFF
N35 #KIN ID[0]
N40 G70 G80 G90
N45 G17 G40
N50 G53
N55 G0 #MCS Z0
N60 #MCS X0 Y0
N65 #MCS B0. C0.
N70 ; FACE1
N75 T10 M6
N80 #MCS Z0
N85 #MCS X0 Y0
  safeRetractDistance: {
    title      : "Safe retract distance",
    description: "A set distance to add to the tool length for rewind C-axis tool retract.",
    group      : "multiAxis",
    type       : "number",
    scope      : "post"
  safeZHeight: {
    title      : "Safe Z height (in)",
    description: "Safe retract height (in inches) for operations in G53 mode.",
    group      : "homePositions",
    type       : "number",
    value      : 0,
    scope      : "post"
  Copyright (C) 2012-2024 by Autodesk, Inc.
  All rights reserved.
  FAGOR post processor configuration.
  $Revision: 44115 1104db9da08471dc1d758431fd9ef8822fd95c21 $
  $Date: 2024-03-12 07:10:57 $
  FORKID {AFBF02F9-62E3-4ec8-9FE8-4B1705B25A49}
//                        MANUAL NC COMMANDS
// The following ACTION commands are supported by this post.
//     useVTable                  - Use the V-table for this operation
//     useYTable                  - Use the Y-table for this operation
description = "DMS Router with FAGOR 8065 Control";
vendor = "Diversified Machine Systems DMS";
vendorUrl = "http://dmscncrouters.com";
legal = "Copyright (C) 2012-2024 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 45811;
longDescription = "Generic 5-axis post for DMS routers with a FAGOR 8065 control.";
extension = "nc";
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  writeMachine: {
    title      : "Write machine",
    description: "Output the machine settings in the header of the code.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  writeTools: {
    title      : "Write tool list",
    description: "Output a tool list in the header of the code.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  preloadTool: {
    title      : "Preload tool",
    description: "Preloads the next tool at a tool change (if any).",
    group      : "preferences",
    type       : "boolean",
    value      : true,
    scope      : "post"
  showSequenceNumbers: {
    title      : "Use sequence numbers",
    description: "'Yes' outputs sequence numbers on each block, 'Only on tool change' outputs sequence numbers on tool change blocks only, and 'No' disables the output of sequence numbers.",
    group      : "formats",
    type       : "enum",
    values     : [
      {title:"Yes", id:"true"},
      {title:"No", id:"false"},
      {title:"Only on tool change", id:"toolChange"}
    value: "true",
    scope: "post"
  sequenceNumberStart: {
    title      : "Start sequence number",
    description: "The number at which to start the sequence numbers.",
    group      : "formats",
    type       : "integer",
    value      : 10,
    scope      : "post"
  sequenceNumberIncrement: {
    title      : "Sequence number increment",
    description: "The amount by which the sequence number is incremented by in each block.",
    group      : "formats",
    type       : "integer",
    value      : 5,
    scope      : "post"
  optionalStop: {
    title      : "Optional stop",
    description: "Outputs optional stop code during when necessary in the code.",
    type       : "boolean",
    value      : true,
    scope      : "post"
  separateWordsWithSpace: {
    title      : "Separate words with space",
    description: "Adds spaces between words if 'yes' is selected.",
    group      : "formats",
    type       : "boolean",
    value      : true,
    scope      : "post"
  useVTable: {
    title      : "Use V table",
    description: "Defaults to the Y-table.",
    type       : "boolean",
    value      : false,
    scope      : "post"
  fifthAxis: {
    title      : "Five axis",
    description: "Defines whether the machine is a 5-axis router.",
    group      : "configuration",
    type       : "boolean",
    value      : true,
    scope      : "post"
  gotContinuousCAxis: {
    title      : "Continuous C-axis",
    description: "If enabled, the C-axis is continuous with no limits.",
    type       : "boolean",
    value      : false,
    scope      : "post"
    type       : "number",
    scope      : "post"
  safeZHeight: {
    description: "Safx`.",
    type       : "number",
    scope      : "post"
  useParkPosition: {
    title      : "Park XY position",
    description: "XY park position in G53/MCS mode.",
    type       : "string",
    value      : "0.0","0.0"
    scope      : "post"
  contouringAcceleration: {
    title      : "Contouring acceleration",
    description: "Acceleration percentage used for G51 look-ahead smoothing.",
    type       : "number",
    value      : 100,
    scope      : "post"
  contouringError: {
    title      : "Contouring error",
    description: "Error allowed during G52 look-ahead smoothing.",
    type       : "number",
    value      : 0.001,
    scope      : "post"
  forceHomeOnIndexing: {
    title      : "Force home position on indexing",
    description: "Force home position on multi-axis indexing.",
    type       : "boolean",
    value      : true,
    scope      : "post"
  cAxisLinearScale: {
    title      : "C-axis moves on a linear scale",
    description: "Set to false to output continuous C-axis between 0-360 degrees.",
    type       : "boolean",
    value      : false,
    scope      : "post"
  useG58: {
    title      : "Output G58 after WCS selection",
    description: "Enable to output a G58 code after the selected WCS code is output.",
    type       : "boolean",
    value      : true,
    scope      : "post"
  useDustCollector: {
    title      : "Enable the dust collector at start of program",
    description: "Enable to open the dust collector shroud at the start of the program and disable it at the end of the program." +
      "Disable to use Flood Coolant to open the dust collector shroud at the beginning of an operation.",
    group: "preferences",
    type : "boolean",
    value: false,
    scope: "post"
  safePositionMethod: {
    title      : "Safe Retracts",
    description: "Select your desired retract option.",
    type       : "enum",
    values     : [
      {title:"G53", id:"G53"},
      {title:"MCS", id:"MCS"}
    value: "G53",
    scope: "post"
// wcs definiton
wcsDefinitions = {
  useZeroOffset: false,
  wcs          : [
    {name:"Standard", format:"G", range:[54, 57]},
    {name:"Extended", format:"G159 =", range:[5, 20]}
var singleLineCoolant = false; // specifies to output multiple coolant codes in one line rather than in separate lines
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
// {id: COOLANT_THROUGH_TOOL, on: "M88 P3 (myComment)", off: "M89"}
var coolants = [
  {id:COOLANT_FLOOD, on:66, off:65},
  {id:COOLANT_MIST},
  {id:COOLANT_THROUGH_TOOL},
  {id:COOLANT_AIR},
  {id:COOLANT_AIR_THROUGH_TOOL},
  {id:COOLANT_SUCTION},
  {id:COOLANT_FLOOD_MIST},
  {id:COOLANT_FLOOD_THROUGH_TOOL},
  {id:COOLANT_OFF, off:66}
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var gFormat = createFormat({prefix:"G", decimals:0});
var mFormat = createFormat({prefix:"M", decimals:0});
var dFormat = createFormat({prefix:"D", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4)});
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 5 : 5)});
var feedTimeFormat = createFormat({decimals:5, forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var kFormat = createFormat({decimals:4}); // seconds - range 0-99999
var taperFormat = createFormat({decimals:1, scale:DEG});
var eFormat = createFormat({decimals:5});
var accelFormat = createFormat({decimals:0});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange:function() {retracted = false;}, prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var inverseTimeOutput = createVariable({prefix:"F", force:true}, feedTimeFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({force:true}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G16-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G94-95
var gUnitModal = createModal({}, gFormat); // modal group 6 // G70-71
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
var gTableModal = createModal({}, gFormat); // modal group 11 // G28-29
var gWCSModal = createModal({}, gFormat); // modal group 12 // G53-G59
// fixed settings
var maxFeedRate = 99999.99999;
var pivotDistance = toPreciseUnit(8.2202, IN); // distance to pivot point along B-axis
var headOffset = pivotDistance; // can have the tool length added to it
var safeRetractFeed = (unit == IN) ? 40 : 1000;
var safePlungeFeed = (unit == IN) ? 25 : 625;
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var forceSpindleSpeed = false;
var currentWorkOffset;
var currentPlane;
var previousABC = new Vector(0, 0, 0);
var parkPosition = new Vector(0, 0, 0);
var vTableActive = false;
var retracted = false; // specifies that the tool has been retracted to the safe plane
var rotaryScale;
var retractPlane;
function getG16(plane) {
  if (currentPlane != plane) {
    currentPlane = plane;
    return formatWords(gFormat.format(16), plane);
  return [];
  Writes the specified block.
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
  if (getProperty("showSequenceNumbers") == "true") {
    writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += getProperty("sequenceNumberIncrement");
  } else {
    writeWords(arguments);
  Writes the specified block - used for tool changes only.
function writeToolBlock() {
  var show = getProperty("showSequenceNumbers");
  setProperty("showSequenceNumbers", (show == "true" || show == "toolChange") ? "true" : "false");
  writeBlock(arguments);
  setProperty("showSequenceNumbers", show);
  Output a comment.
function writeComment(text) {
  writeBlock("; " + filterText(String(text).toUpperCase(), permittedCommentChars));
  Parses a string containing two values (0,0).
function parseXY(_text) {
  var limits = {min:0, max:0};
  var tmpArray = parseNumbers(_text, 2);
  if (tmpArray[0] != 2) {
    writeFatal(localize("Property table limits are in the wrong format."));
    return new Vector(0, 0, 0);
  } else {
    return new Vector(tmpArray[1], tmpArray[2], 0);
function parseNumbers(_text, _max) {
  // extract values between commas
  var sText1 = _text;
  var sText2 = new Array();
  var retCoord = new Array();
  sText2 = sText1.split(",");
  retCoord[0] = sText2.length;
  // too many values, return 0
  if (retCoord[0] > _max) {
    retCoord[0] = 0;
    return retCoord;
  // parse numbers,  if a string is not a valid number, then return 0
  for (i = 0; i < retCoord[0]; i++) {
    retCoord[i + 1] = parseFloat(sText2[i]);
    // if a string is not a valid number, then return 0
    if (isNaN(retCoord[i])) {
      retCoord[0] = 0;
      return retCoord;
  return retCoord;
function onOpen() {
  rotaryScale = getProperty("gotContinuousCAxis") && !getProperty("cAxisLinearScale");
  // define XYZ home position
  parkPosition = parseXY(getProperty("useParkPosition"));
  if (getProperty("fifthAxis")) {
    var bAxis = createAxis({coordinate:1, table:false, axis:[0, -1, 0], range:[-125.000, 125.000]});
    var cAxis;
    if (getProperty("gotContinuousCAxis")) {
      if (getProperty("cAxisLinearScale")) {
        cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, -1], cyclic:true, preference:0});
      } else {
        cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, -1], cyclic:true, range:[0.0, 360.0], preference:0});
    } else {
      cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, -1], cyclic:false, range:[-365.0, 365.0], preference:0});
    machineConfiguration = new MachineConfiguration(bAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // TCP mode
  machineConfiguration.setRetractPlane(toPreciseUnit(getProperty("safeZHeight"), IN));
  retractPlane = getProperty("safeZHeight");
  if (!machineConfiguration.isMachineCoordinate(0)) {
    aOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(1)) {
    bOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(2)) {
    cOutput.disable();
  if (!getProperty("separateWordsWithSpace")) {
    setWordSeparator("");
  sequenceNumber = getProperty("sequenceNumberStart");
  var fileName = FileSystem.getFilename(FileSystem.replaceExtension(getOutputPath(), "xxx").split(".xxx", 1));
  if (!fileName) {
    if (programComment) {
      fileName = programComment;
    } else if (programName) {
      fileName = programName;
    } else {
      error(localize("Program name has not been specified."));
      return;
  writeln(fileName.slice(0, 14).replace(/[ ]/g, "_")); // max 14 chars
    writeComment(programComment);
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (getProperty("writeMachine") && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  // dump tool information
  if (getProperty("writeTools")) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + "  " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
    for (var i = 0; i < getNumberOfSections(); ++i) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  // startup blocks
  writeBlock("#MCS OFF"); // Use part system
  writeBlock("#CS OFF"); // Part coordinate system
    writeBlock("#RTCP OFF"); // Cancel TCP transformation
    writeBlock("#HSC OFF"); // Disable contouring error
    writeBlock("#KIN ID[0]"); // Kinematics style
  writeBlock(gUnitModal.format(unit == IN ? 70 : 71), gCycleModal.format(80), gAbsIncModal.format(90));
  writeBlock(gPlaneModal.format(17), gFormat.format(40));
  writeBlock(gFormat.format(53));
  if (getProperty("useDustCollector")) {
    writeBlock(getCoolantCodes(COOLANT_FLOOD));
  if (getProperty("useVTable")) {
    swapVTable(true, false);
function onComment(message) {
  writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
  aOutput.reset();
  bOutput.reset();
  cOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
  forceXYZ();
  forceABC();
  feedOutput.reset();
var currentSmoothing = undefined;
function setSmoothing(mode) {
  if (mode == currentSmoothing) {
    return false;
  currentSmoothing = mode;
  if (mode) {
    writeBlock(gFormat.format(501),
      "A" + accelFormat.format(getProperty("contouringAcceleration")),
      "E" + eFormat.format(getProperty("contouringError")),
      mFormat.format(2)
  } else {
    writeBlock(gFormat.format(7));
  return true;
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
  if (!machineConfiguration.isMultiAxisConfiguration()) {
    return; // ignore
  if (!((currentWorkPlaneABC == undefined) ||
        abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
        abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
        abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
    return; // no change
  onCommand(COMMAND_UNLOCK_MULTI_AXIS);
  var plane = calculateRetractPlane(abc);
  if (plane < retractPlane) {
    retractPlane = plane;
    writeRetract(Z);
    currentWorkOffset = undefined;
    writeWCS();
  writeBlock(
    gMotionModal.format(0),
    conditional(machineConfiguration.isMachineCoordinate(0), aOutput.format(abc.x)),
    conditional(machineConfiguration.isMachineCoordinate(1), bOutput.format(abc.y)),
    conditional(machineConfiguration.isMachineCoordinate(2),
      cOutput.format(getDirectionalABC(previousABC.z, abc.z, cOutput, rotaryScale)))
  onCommand(COMMAND_LOCK_MULTI_AXIS);
  currentWorkPlaneABC = abc;
  previousABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
  var W = workPlane; // map to global frame
  var abc = machineConfiguration.getABC(W);
  if (closestABC) {
    if (currentMachineABC) {
      abc = machineConfiguration.remapToABC(abc, currentMachineABC);
    } else {
      abc = machineConfiguration.getPreferredABC(abc);
  } else {
  try {
    abc = machineConfiguration.remapABC(abc);
    currentMachineABC = abc;
  } catch (e) {
    error(
      localize("Machine angles not supported") + ":"
      + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
      + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
      + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
  var direction = machineConfiguration.getDirection(abc);
  if (!isSameDirection(direction, W.forward)) {
    error(localize("Orientation not supported."));
  if (!machineConfiguration.isABCSupported(abc)) {
    error(
      localize("Work plane is not supported") + ":"
  var tcp = true;
  if (tcp) {
    setRotation(W); // TCP mode
  } else {
    var O = machineConfiguration.getOrientation(abc);
    var R = machineConfiguration.getRemainingOrientation(abc, W);
    setRotation(R);
  return abc;
function swapVTable(_vTable, _swap) {
  if (_vTable) {
    writeBlock(gTableModal.format(28), "YV");
    if (_swap) {
      writeComment("add table swap codes here");
    vTableActive = true;
  } else {
    writeBlock(gTableModal.format(29), "Y");
    if (_swap) {
function writeWCS() {
  if (currentSection.workOffset != currentWorkOffset) {
    gWCSModal.reset();
    writeBlock(currentSection.wcs);
    if (currentSection.workOffset < 4 && getProperty("useG58")) {
      writeln(";(ORGX58=0,ORGY58=0,ORGZ58=0)");
      writeBlock(gFormat.format(58));
    currentWorkOffset = currentSection.workOffset;
function onSection() {
  var insertToolCall = isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  retracted = false;
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  var newWorkPlane = isFirstSection() ||
    !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
    (currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
      Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
    (!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
    (!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
      getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
  var forceSmoothing =
    (hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill") ||
    !isFirstSection() && getPreviousSection().hasParameter("operation-strategy") && (getPreviousSection().getParameter("operation-strategy") == "drill")); // force smoothing in case !insertToolCall (2d chamfer)
  if (insertToolCall || newWorkOffset || newWorkPlane || forceSmoothing) {
    // stop spindle before retract during tool change
    if (insertToolCall && !isFirstSection()) {
      onCommand(COMMAND_STOP_SPINDLE);
      if (!getProperty("useDustCollector")) {
        setCoolant(COOLANT_OFF);
    if (insertToolCall || newWorkOffset || newWorkPlane) {
      // retract tool
      zOutput.reset();
      retractPlane = calculateRetractPlane(previousABC);
      writeRetract(Z);
      if (getProperty("forceHomeOnIndexing")) {
        writeRetract(X, Y);
      if (machineConfiguration.isMultiAxisConfiguration()) {
        forceABC();
        var abc = new Vector(0, 0, 0);
        if (currentSection.isMultiAxis() && !rotaryScale) {
          abc = currentSection.getInitialToolAxisABC();
        abc = machineConfiguration.remapToABC(new Vector(0, 0, 0), abc);
        writeBlock(getProperty("safePositionMethod") == "G53" ? gFormat.format(53) : "#MCS", aOutput.format(0), bOutput.format(0), cOutput.format(abc.z));
    if ((insertToolCall && !isFirstSection()) || forceSmoothing) {
      setSmoothing(false);
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
  if (insertToolCall) {
    forceWorkPlane();
    if (!isFirstSection() && getProperty("optionalStop")) {
      onCommand(COMMAND_OPTIONAL_STOP);
    if (tool.number > 99) {
      warning(localize("Tool number exceeds maximum value."));
    writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
    if (tool.comment) {
      writeComment(tool.comment);
    if (getProperty("fifthAxis")) { // tool change causes position change, move it back to its home position
      writeRetract(Z);
        writeRetract(X, Y);
    var showToolZMin = false;
    if (showToolZMin) {
      if (is3D()) {
        var zRange = currentSection.getGlobalZRange();
        var number = tool.number;
        for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
          if (section.getTool().number != number) {
            break;
          zRange.expandToRange(section.getGlobalZRange());
        writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
    if (getProperty("preloadTool")) {
      var nextTool = getNextTool(tool.number);
      if (nextTool) {
        writeBlock("T" + toolFormat.format(nextTool.number));
      } else {
        // preload first tool
        var section = getSection(0);
        var firstToolNumber = section.getTool().number;
        if (tool.number != firstToolNumber) {
          writeBlock("T" + toolFormat.format(firstToolNumber));
  var spindleChanged = tool.type != TOOL_PROBE &&
    (insertToolCall || forceSpindleSpeed || isFirstSection() ||
    (rpmFormat.areDifferent(spindleSpeed, sOutput.getCurrent())) ||
    (tool.clockwise != getPreviousSection().getTool().clockwise));
  if (spindleChanged) {
    if (spindleSpeed < 1) {
      error(localize("Spindle speed out of range."));
      return;
    if (spindleSpeed > 99999) {
      warning(localize("Spindle speed exceeds maximum value."));
    writeBlock(sOutput.format(spindleSpeed));
    writeBlock(mFormat.format(tool.clockwise ? 3 : 4));
    onDwell(3.0);
  forceXYZ();
  headOffset = tool.bodyLength + pivotDistance;
  if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
    // set working plane after datum shift
    var abc;
    if (currentSection.isMultiAxis()) {
      forceWorkPlane();
      cancelTransformation();
    } else {
      abc = getWorkPlaneMachineABC(currentSection.workPlane);
    setWorkPlane(abc);
  } else { // pure 3D
    var remaining = currentSection.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return;
    setRotation(remaining);
  // wcs
  if (insertToolCall) { // force work offset when changing tool
  writeWCS();
  if ((insertToolCall || forceSmoothing) && getProperty("fifthAxis")) {
    writeBlock("#KIN ID[1]");
    writeBlock("#RTCP ON");
    //writeBlock("#HSC ON[CONTERROR " + xyzFormat.format(tolerance) + "]");
    setSmoothing(!(hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill")));
  forceXYZ();
  // set coolant after we have positioned at Z
    setCoolant(tool.coolant);
  var initialPosition = getFramePosition(currentSection.getInitialPosition());
  if (!retracted && !insertToolCall) {
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
  if (insertToolCall || retracted) {
    // control uses D-word for length offset also
    var lengthOffset = tool.lengthOffset;
    if (lengthOffset > 99) {
      error(localize("Length offset out of range."));
      return;
      writeBlock(dOutput.format(1)); // D1 is always used for tool offset, CNC adjust for actual Active tool offset
    currentPlane = undefined;
    writeBlock(gPlaneModal.format(17));
    if (!machineConfiguration.isHeadConfiguration()) {
      writeBlock(
        gAbsIncModal.format(90),
        gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
      writeBlock(
        conditional(!getProperty("fifthAxis"), gFormat.format(43)),
        zOutput.format(initialPosition.z), conditional(!getProperty("fifthAxis"))
    } else {
      writeBlock(
  } else {
    writeBlock(
function onDwell(seconds) {
  if (seconds > 999.99) {
    warning(localize("Dwelling time is out of range."));
  time = clamp(0.0001, seconds, 999.99);
  writeBlock(gFormat.format(4), "K" + kFormat.format(time));
function onSpindleSpeed(spindleSpeed) {
  onDwell(3.0);
function onCycle() {
function getCommonCycle(x, y, reference, bottom) {
  forceXYZ();
  return [xOutput.format(x), yOutput.format(y),
    "Z" + xyzFormat.format(reference),
    "I" + xyzFormat.format(bottom)];
function onCyclePoint(x, y, z) {
  if (!isSameDirection(getRotation().forward, new Vector(0, 0, 1))) {
    expandCyclePoint(x, y, z);
    return;
  if (isFirstCyclePoint()) {
    repositionToCycleClearance(cycle, x, y, z);
    // return to initial Z which is clearance plane and set absolute mode
    var F = cycle.feedrate;
    var K = (cycle.dwell == 0) ? 0 : clamp(0.001, cycle.dwell, 999.999);
    switch (cycleType) {
    case "drilling":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81),
        getCommonCycle(x, y, cycle.retract, cycle.bottom),
        ((K > 0) ? "K" + kFormat.format(K) : ""),
        feedOutput.format(F)
      break;
    case "counter-boring":
      break;
    case "chip-breaking":
      if ((cycle.accumulatedDepth < cycle.depth) || (P > 0)) {
      } else {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82),
          "B" + xyzFormat.format(cycle.incrementalDepth),
          // "C" + xyzFormat.format(machineParameters.drillingSafeDistance),
          "D" + xyzFormat.format(cycle.retract - cycle.stock),
          "H" + xyzFormat.format((cycle.chipBreakDistance != undefined) ? cycle.chipBreakDistance : machineParameters.chipBreakingDistance),
          "J" + cycle.plungesPerRetract,
          ((cycle.minimumIncrementalDepth > 0) ? "L" + xyzFormat.format(cycle.minimumIncrementalDepth) : ""),
          ((cycle.incrementalDepthReduction > 0) ? "R" +
            xyzFormat.format(1 - (cycle.incrementalDepthReduction / cycle.incrementalDepth)) : ""),
      break;
    case "deep-drilling":
      if ((cycle.incrementalDepthReduction > 0) || (K > 0)) {
        writeBlock(
          "J1",
      } else {
        var plunges = Math.max(Math.floor((cycle.retract - cycle.bottom) / cycle.incrementalDepth), 1);
        var incrementalDepth = -(cycle.retract - cycle.bottom) / plunges;
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
          xOutput.format(x) + yOutput.format(y),
          "Z" + xyzFormat.format(cycle.retract),
          "I" + xyzFormat.format(incrementalDepth),
          "J" + xyzFormat.format(plunges),
      break;
    case "tapping":
      if (tool.type == TOOL_TAP_LEFT_HAND) {
      } else {
        if (!F) {
          F = tool.getTappingFeedrate();
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84),
          "R0", feedOutput.format(F)
      break;
    case "left-tapping":
      break;
    case "right-tapping":
      if (!F) {
      writeBlock(
      break;
    case "back-boring":
      break;
    case "reaming":
      if (feedFormat.getResultingValue(cycle.feedrate) != feedFormat.getResultingValue(cycle.retractFeedrate)) {
        break;
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85),
      break;
    case "fine-boring":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86),
        "Q" + abcFormat.format(cycle.shiftOrientation),
        "D" + xyzFormat.format(cycle.shift),
      break;
    case "manual-boring":
      break;
    case "boring":
        break;
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89),
      break;
    default:
  } else {
    if (cycleExpanded) {
    } else {
      writeBlock(xOutput.format(x), yOutput.format(y));
function onCycleEnd() {
  if (!cycleExpanded) {
    writeBlock(gCycleModal.format(80));
    zOutput.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
    feedOutput.reset(); // not required for 8040M
function onLinear(_x, _y, _z, feed) {
  var f = feedOutput.format(feed);
  if (x || y || z) {
      var d = tool.diameterOffset;
      if (d > 99) {
        warning(localize("The diameter offset exceeds the maximum value."));
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        dOutput.reset();
        writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
        break;
      case RADIUS_COMPENSATION_RIGHT:
        dOutput.reset();
        writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
        break;
      default:
        writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(40), x, y, z, f);
    } else {
      writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      feedOutput.reset(); // force feed on next line
    } else {
      writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
  if (!currentSection.isOptimizedForMachine()) {
    error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
    return;
    return;
  var a = aOutput.format(_a);
  var b = bOutput.format(_b);
  var c = cOutput.format(getDirectionalABC(previousABC.z, _c, cOutput, rotaryScale));
  if (x || y || z || a || b || c) {
    writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
    previousABC = new Vector(_a, _b, _c);
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
    return;
    error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
    return;
    writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), x, y, z, a, b, c, f);
  } else if (f) {
    } else {
/** Calculate angles on rotary scale with signed direction. */
function getDirectionalABC(_startAngle, _endAngle, _output, _directionFlag) {
  var signedAngle = _endAngle;
  if (_directionFlag) {
    // angles are the same, set the previous output angle to the current angle so it is not output
    if (!abcFormat.areDifferent(_startAngle, _endAngle)) {
      _output.format(_startAngle);
    // calculate the correct direction (sign) based on CLW/CCW direction
    var delta = abcFormat.getResultingValue(_endAngle - _startAngle);
    if (((delta < 0) && (delta > -180.0)) || (delta > 180.0)) {
      if (_endAngle == 0) {
        signedAngle = -Math.PI * 2;
      } else {
        signedAngle = -_endAngle;
  return signedAngle;
// Start of onRewindMachine logic
/***** Be sure to add 'safeRetractDistance' to post getProperty(" ")*****/
var performRewinds = true; // enables the onRewindMachine logic
var safeRetractFeed = (unit == IN) ? 20 : 500;
var safePlungeFeed = (unit == IN) ? 10 : 250;
var stockAllowance = new Vector(toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN), toPreciseUnit(0.1, IN));
/** Allow user to override the onRewind logic. */
function onRewindMachineEntry(_a, _b, _c) {
    return true;
  return false;
/** Retract to safe position before indexing rotaries. */
function moveToSafeRetractPosition(isRetracted) {
  writeRetract(Z);
    writeRetract(X, Y);
  writeWCS();
/** Return from safe position after indexing rotaries. */
function returnFromSafeRetractPosition(position) {
  forceXYZ();
  xOutput.reset();
  yOutput.reset();
  zOutput.disable();
  onExpandedRapid(position.x, position.y, position.z);
  zOutput.enable();
/** Intersect the point-vector with the stock box. */
function intersectStock(point, direction) {
  var intersection = getWorkpiece().getRayIntersection(point, direction, stockAllowance);
  return intersection === null ? undefined : intersection.second;
/** Calculates the retract point using the stock box and safe retract distance. */
function getRetractPosition(currentPosition, currentDirection) {
  var retractPos = intersectStock(currentPosition, currentDirection);
  if (retractPos == undefined) {
    if (tool.getFluteLength() != 0) {
      retractPos = Vector.sum(currentPosition, Vector.product(currentDirection, tool.getFluteLength()));
  if ((retractPos != undefined) && getProperty("safeRetractDistance")) {
    retractPos = Vector.sum(retractPos, Vector.product(currentDirection, getProperty("safeRetractDistance")));
  return retractPos;
/** Determines if the angle passed to onRewindMachine is a valid starting position. */
function isRewindAngleValid(_a, _b, _c) {
  // make sure the angles are different from the last output angles
  if (!abcFormat.areDifferent(getCurrentDirection().x, _a) &&
      !abcFormat.areDifferent(getCurrentDirection().y, _b) &&
      !abcFormat.areDifferent(getCurrentDirection().z, _c)) {
    error(
      localize("REWIND: Rewind angles are the same as the previous angles: ") +
      abcFormat.format(_a) + ", " + abcFormat.format(_b) + ", " + abcFormat.format(_c)
    return false;
  // make sure angles are within the limits of the machine
  var abc = new Array(_a, _b, _c);
  var ix = machineConfiguration.getAxisU().getCoordinate();
  var failed = false;
  if ((ix != -1) && !machineConfiguration.getAxisU().isSupported(abc[ix])) {
    failed = true;
  ix = machineConfiguration.getAxisV().getCoordinate();
  if ((ix != -1) && !machineConfiguration.getAxisV().isSupported(abc[ix])) {
    failed = true;
  ix = machineConfiguration.getAxisW().getCoordinate();
  if ((ix != -1) && !machineConfiguration.getAxisW().isSupported(abc[ix])) {
    failed = true;
  if (failed) {
    error(
      localize("REWIND: Rewind angles are outside the limits of the machine: ") +
    return false;
  return true;
function onRewindMachine(_a, _b, _c) {
  if (!performRewinds) {
    error(localize("REWIND: Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled."));
    return;
  // Allow user to override rewind logic
  if (onRewindMachineEntry(_a, _b, _c)) {
    return;
  // Determine if input angles are valid or will cause a crash
  if (!isRewindAngleValid(_a, _b, _c)) {
    error(
      localize("REWIND: Rewind angles are invalid:") +
    return;
  // Work with the tool end point
  if (currentSection.getOptimizedTCPMode() == 0) {
    currentTool = getCurrentPosition();
  } else {
    currentTool = machineConfiguration.getOrientation(getCurrentDirection()).multiply(getCurrentPosition());
  var currentABC = getCurrentDirection();
  var currentDirection = machineConfiguration.getDirection(currentABC);
  // Calculate the retract position
  var retractPosition = getRetractPosition(currentTool, currentDirection);
  // Output warning that axes take longest route
  if (retractPosition == undefined) {
    error(localize("REWIND: Cannot calculate retract position."));
    return;
  } else {
    var text = localize("REWIND: Tool is retracting due to rotary axes limits.");
    warning(text);
    writeComment(text);
  // Move to retract position
  var position;
    position = retractPosition;
  } else {
    position = machineConfiguration.getOrientation(getCurrentDirection()).getTransposed().multiply(retractPosition);
  onExpandedLinear(position.x, position.y, position.z, safeRetractFeed);
  //Position to safe machine position for rewinding axes
  moveToSafeRetractPosition(false);
  // Rotate axes to new position above reentry position
  xOutput.disable();
  yOutput.disable();
  zOutput.disable();
  onRapid5D(position.x, position.y, position.z, _a, _b, _c);
  xOutput.enable();
  yOutput.enable();
  zOutput.enable();
  // Move back to position above part
  if (currentSection.getOptimizedTCPMode() != 0) {
    position = machineConfiguration.getOrientation(new Vector(_a, _b, _c)).getTransposed().multiply(retractPosition);
  returnFromSafeRetractPosition(position);
  // Plunge tool back to original position
    currentTool = machineConfiguration.getOrientation(new Vector(_a, _b, _c)).getTransposed().multiply(currentTool);
  onExpandedLinear(currentTool.x, currentTool.y, currentTool.z, safePlungeFeed);
// End of onRewindMachine logic
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  var start = getCurrentPosition();
  if (isFullCircle()) {
    if (isHelical()) {
      linearize(tolerance);
      return;
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed));
      break;
    case PLANE_ZX:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
      break;
    case PLANE_YZ:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
      break;
    default:
  } else {
    case PLANE_XY:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), zOutput.format(z), feedOutput.format(feed));
      break;
    case PLANE_ZX:
      if (isHelical()) {
        return;
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
      break;
    case PLANE_YZ:
      if (isHelical()) {
        return;
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
      break;
    default:
function onParameter(name, value) {
  switch (name) {
  case "action":
    var errFlag = false;
    if (String(value).toUpperCase() == "USEVTABLE") {
      swapVTable(true, !vTableActive);
    } else if (String(value).toUpperCase() == "USEYTABLE") {
      swapVTable(false, vTableActive);
    } else {
      error(localize("Invalid action parameter: ") + value);
      return;
    break;
function parseToggle() {
  var stat = undefined;
  for (i = 1; i < arguments.length; i++) {
    if (String(arguments[0]).toUpperCase() == String(arguments[i]).toUpperCase()) {
      if (String(arguments[i]).toUpperCase() == "YES") {
        stat = true;
      } else if (String(arguments[i]).toUpperCase() == "NO") {
        stat = false;
      } else {
        stat = i - 1;
        break;
  return stat;
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
var forceCoolant = false;
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
function getCoolantCodes(coolant) {
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (tool.type && tool.type == TOOL_PROBE) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode && (!forceCoolant || coolant == COOLANT_OFF)) {
    return undefined; // coolant is already active
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF) && (coolantOff != undefined) && !forceCoolant) {
    if (Array.isArray(coolantOff)) {
      for (var i in coolantOff) {
        multipleCoolantBlocks.push(coolantOff[i]);
    } else {
      multipleCoolantBlocks.push(coolantOff);
  var m;
  var coolantCodes = {};
  for (var c in coolants) { // find required coolant codes into the coolants array
    if (coolants[c].id == coolant) {
      coolantCodes.on = coolants[c].on;
      if (coolants[c].off != undefined) {
        coolantCodes.off = coolants[c].off;
        break;
      } else {
        for (var i in coolants) {
          if (coolants[i].id == COOLANT_OFF) {
            coolantCodes.off = coolants[i].off;
            break;
  if (coolant == COOLANT_OFF) {
    m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
  } else {
    coolantOff = coolantCodes.off;
    m = coolantCodes.on;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  } else {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(m[i]);
    } else {
      multipleCoolantBlocks.push(m);
    currentCoolantMode = coolant;
    for (var i in multipleCoolantBlocks) {
      if (typeof multipleCoolantBlocks[i] == "number") {
        multipleCoolantBlocks[i] = mFormat.format(multipleCoolantBlocks[i]);
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
var mapCommand = {
  COMMAND_STOP                    : 0,
  COMMAND_OPTIONAL_STOP           : 1,
  COMMAND_END                     : 2,
  COMMAND_SPINDLE_CLOCKWISE       : 3,
  COMMAND_SPINDLE_COUNTERCLOCKWISE: 4,
  COMMAND_STOP_SPINDLE            : 5,
  COMMAND_ORIENTATE_SPINDLE       : 19,
  COMMAND_LOAD_TOOL               : 6
function onCommand(command) {
  switch (command) {
  case COMMAND_STOP:
    writeBlock(mFormat.format(0));
    forceSpindleSpeed = true;
    forceCoolant = true;
    return;
  case COMMAND_OPTIONAL_STOP:
    writeBlock(mFormat.format(1));
    return;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_LOCK_MULTI_AXIS:
    return;
  case COMMAND_UNLOCK_MULTI_AXIS:
    return;
  case COMMAND_BREAK_CONTROL:
    return;
  case COMMAND_TOOL_MEASURE:
    writeBlock(mFormat.format(100 + tool.number));
    return;
  var stringId = getCommandStringId(command);
  var mcode = mapCommand[stringId];
  if (mcode != undefined) {
    writeBlock(mFormat.format(mcode));
  } else {
    onUnsupportedCommand(command);
function onSectionEnd() {
  if (!isLastSection() && (getNextSection().getTool().coolant != tool.coolant) && !getProperty("useDustCollector")) {
  forceAny();
/** Calculates the retract plane based on the A-axis position. */
function calculateRetractPlane(_abc) {
  var plane = machineConfiguration.getRetractPlane();
  if (Math.abs(_abc.y) > (Math.PI / 2)) {
    plane -= Math.sin(Math.abs(_abc.y) - (Math.PI / 2)) * headOffset;
  return plane;
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  if (arguments.length == 0) {
    error(localize("No axis specified for writeRetract()."));
    return;
  var method = getProperty("safePositionMethod");
  var words = []; // store all retracted axes in an array
  for (var i = 0; i < arguments.length; ++i) {
    let instances = 0; // checks for duplicate retract calls
    for (var j = 0; j < arguments.length; ++j) {
      if (arguments[i] == arguments[j]) {
        ++instances;
    if (instances > 1) { // error if there are multiple retract calls for the same axis
      error(localize("Cannot retract the same axis twice in one line"));
      return;
    switch (arguments[i]) {
    case X:
      words.push("X" + parkPosition.x);
      break;
    case Y:
      words.push("Y" + parkPosition.y);
      break;
    case Z:
      words.push("Z" + xyzFormat.format(retractPlane));
      retracted = true; // specifies that the tool has been retracted to the safe plane
      zOutput.reset();
      break;
    default:
      error(localize("Bad axis specified for writeRetract()."));
      return;
  if (words.length > 0) {
    switch (method) {
    case "G53":
      writeBlock(gMotionModal.format(0), gWCSModal.format(53), words); // retract
      break;
    case "MCS":
      writeBlock(gMotionModal.format(0), "#MCS", words); // retract
      break;
function onClose() {
  zOutput.reset();
  writeRetract(Z);
  writeRetract(X, Y);
  forceABC();
  forceWorkPlane();
  setWorkPlane(new Vector(0, 0, 0)); // reset working plane
  if (vTableActive) {
    swapVTable(false, false);
  onImpliedCommand(COMMAND_END);
  writeBlock(mFormat.format(30)); // stop program, spindle stop
  //writeln("%");
Replies (0)
