Fagor 8055T Turning Post Wanted
JaysAutoService
JaysAutoService
Hello all. Does anybody have a turning post for a Fagor 8055T. I'm more than pay for something that works.
There is one here wack fagor in the search field it is the first one that pops up
https://cam.autodesk.com/hsmposts?
Paul_NextMedicalDesign
I am using the Fusion360 post for my GT27 lathe with 8037 controller....should be the same syntax as the 8055.  Did you try that one and is it causing you issues?  The post isn't perfect but I might be able to give you workaround if I've seen the same issue....
Paul
JaysAutoService
Hello Paul,
Thanks for responding, I did not find the post that you mentioned. Would
you mind sending it.
Thanks Paul.
Jay
Hi Jay,
I sent you a private msg.
Paul
Hi Jay and others,
The new post 42631 from the library does not work for me on my Fagor 8037 controller.  I thought I'd take a chance and use an updated version....I get "post failed" error every time, which may or may not be related to my message yesterday where I was having problems posting a canned drill operation.  I have been using post 41326 for a couple years and that seems "good enough" (there are a few issues but no show-stoppers).   I am reverting to the older post....something happened between 2017 and now....surprised no one else having issues?
Paul
