Fagor 8055 4th axis turn direction definition
Hi everyone,
I am using a three axis mill with an additional A-Axis, with a Fagor 8055 controller. I am having trouble with the way that the Fagor 8055 post processor is defining a-axis values.
According to the Fagor 8055 installation manual a "normal" rotary axis (Rollover=Yes, Limit +/-=0 ) counts between 0 and 360 degrees, while the sign defines the turn direction. There are a couple of ways that a rotary axis can be defined, and this one seems to be the most logical to me (see attached picture below). However I can“t get Fusion to define a-axis movements in that way.
A functioning solution would be the Limit+/-=8000, Rollover=no -definition, but this would require an unnecessary rewind in case of more than 22 full rotations.
Is there a way of setting this up correctly in Fusion or by changing sth in the post processor?
Many regards,
Thomas
