facing with boring bar
does anyone know a way to face with the boring bar moving from the ID to the OD of part? i can create a separate sketch for the tool path but i want to have fusion recognize the face. when i use "turning face" the software says my tool path is not supported for the tool
jodom4
Hey jthomas,
Can you share an archive (.f3d) file with us?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
i can not for this particular part but its fairly basic design. tubular part with a wall thickness of 1.00". There's a face groove so you have two separate faces to the part and for the bottom face i use an OD turning tool going in the "X-" direction for burr removal. i need to face with a boring bar going in the "X+" direction for the top face
HughesTooling
I think you have to fudge it a bit and use an external tool and rotate it 90°. As you can't share the part you're working on how about making a demo part and upload that.
Mark
Mark Hughes
Owner, Hughes Tooling
