Face turning contour issue
ilan1204
ilan1204
hi
i am trying to perform a simple finish turning profile on my part but fusion360 does not like it i guess 😁.
maybe i am doing something wrong. can some one have a look and explain to me what my mistake is?
this is the profile i am trying to cut:
fusion360 file included!
thanks in advance!
ilan1204
hmmm..., ok i found a solution. i create another sketch that extends the clearance OD and ID and it looks good now.
for some reason fusion360 keeps the profile process until the clearance even if the selected sketch ends. i would expect it to start and end on sketch end and start but it keeps going if the start and end of the sketch is lower than the clearance diameters and then it start making weird stuff like cutting the part.
anyway i include the new working file, maybe it would be useful for someone else.
Christoph_360
Hello
You don't need a Contour for Turning, because of the Solid, Fusion recognizes the geometry that needs to be edited.
I hope that helps.
Christoph
ilan1204
i was talking about the last operation where i use a face turning tool (not groove) to perform the finish profile with chamfers. In my second post i uploaded a project that shows how to do it. In my first post you can see the issue i had with the last process. The grooving part worked just fine.
thanks anyway 😊
Christoph_360
Hello
This can also be easily programmed on the Solid without defining a Contour.
Chistoph
ilan1204
thank you so much Christoph, i am having so much hard time using fusion360 for turning operations and then i see that it is so simple. 🙄
