Face stock
Face stock
hato54
Face stock
hato54
When I facing my stock it leaves a thin edge ( because the object is smaller than the stock?)
The milling path is strange, I need to move it sideways but how?
I really like to face the whole stock  area.
/Håkan
jeff.walters
It looks like you selected something for your stock contours in the operation. If you lear that and run the operations how does it look?
Jeff Walters
Senior Support Engineer, CAM
hato54
Yes I select the contour of the object, so the object is clean but I like to face the whole stock.
Is that possible?
/Håkan
http://a360.co/1zSmuCz
jeff.walters
just clear the object selection(red X) and you should be all set
Jeff Walters
hato54
Sorry, I'm still learning can't understand "clear the object selection(red X)"
Edit:
OK Now I see, thanks!
/Regards
Håkan
jeff.walters
No problem
Jeff Walters
lahaye.hobby
Faced the same issue... which was solved by the same answer. Thanks a lot Jeff.
