F360 interface lock-up/performance issues after Jan update? Workaround inside
brianrepp
Community Manager Community Manager
brianrepp
All - thanks to help from many of you, we've found a source of some performance issues causing the UI to lock-up or appear to have general performance issues in F360.  The issue was introduced in our January update and we have a fixed planned for later this week, but in the meantime please consider the following workaround:
- Disable CAM cloud libraries, and restart Fusion 360
@macmanpb and a few others have confirmed this worked for them, so hopefully it can provide a bit of relief until we get the fix out.
Thanks again,
~Brian
MichaelT_123
Tnkx Brian,
.. also make sure that the at an editing joint's related dialog boxes, the animation is disabled at the start .... it kills the mouse ... as it is probably chasing the same thread.
Stepping into this , I would also like ... when I type ParametersName into an input field that it stays this way and not being converted into numeric value  (even default one )
Best Regards
MichaelT
MichaelT
