Extremely Slow Performance
instcell
instcell
For some reason fusion is ridiculously slow.
This occurs when opening a file with CAM, and also occurs when generating tool paths. Tool paths like 2d contour can now take minutes to generate.
Is anyone else having this problem?
Alex
rasmus.pedersen
Hi @instcell thats odd. Assuming this isn't computer "specific" I think what would be useful is if you could make a screencast of the issue that you are seeing. Does this issue occur regardless of which file/part you are working on?
Rasmus Pedersen
Senior Software Engineer
engineguy
@instcell
Have you tried working "Offline" ?
There may be Internet connection issues in your area so using your computer in "Stand alone" mode will help, if your speeds are good offline then that could be the reason.
Where I am located at certain times of the day Fusion goes slower for me, don`t know if it is my Internet supplier or Fusion Servers just getting busy but going offline does work OK for me.
The other thing that may be causing you some issues could be a local Server within your organisation if you are located in a organisation that has that sort of setup 🙂
