Exporting Multiple NC Programs Simultaneously in Fusion 360
elliotUQYL5
elliotUQYL5
I currently use Alphacam, which allows me to arrange multiple sheets of material and export them all at once. Importantly, it adds a distinctive label to the end of each file name for easy identification. I'm considering or currently using Fusion 360's manufacturing extension and am wondering if it has a similar feature. Specifically, can Fusion 360 batch export different setups as separate NC programs while adding a unique label or identifier to each file name? Any insights into this or related tips for efficient batch processing would be greatly appreciated. Thank you in advance!
marcus.toepke
You can create a post-process configuration for each setup in the production browser and give it the name you want.
Now you can select the postprocessor setups that you want to generate and process them
Now you get files with your labels
I personally use this to output NC-files, tool lists and tool measurement programmes
elliotUQYL5
Thanks for the workaround
