Excessive Linking moves in 3D Pocket when rest-machining
deutirium
deutirium
I make somewhat-complicated 3D Pockets for moulds where I am usually using more than one tool for roughing. This is not specific to one toolpath but is a general problem. It is especially prevalent if I'm using a non-standard tool (In this instance a sloped V-bit, which was preceded by a regular flat endmill). I realise that such a program MUST be complicated given the nature of the pocket and tool being used, but I still think the toolpath could use some optimization as the linking moves are all over the place. Screenshot is an example, but as I mentioned this is a widespread problem in many of my moulds. Are there any parameters which could help clear this up a bit?
programming2C78B
Lets see what you have set on your last tab
Maximum stepdown is relative to your part size
Safe distance can be very small, ie .02"
Please click "Accept Solution" if what I wrote solved your issue!
deutirium
Increasing Safe Distance to 5mm and maximum stay-down to 10mm did not help. Reduced linked but more leads, ultimately a slightly longer machining time.
programming2C78B
.02" is 0.5mm not 5mm
