Excel Setup Sheet Not Functioning with New Post Dialogue
jonathanBUCVS
jonathanBUCVS
Now that the old post dialogue is no longer available, our extremely customized Excel setup sheet does not work. We use this sheet multiple times daily, so this is a critical function for our shop.
I believe the issue is that the .cps post cannot find the .xlsx template because I cannot upload the .xlsx template to the cloud or local post library. Im thinking the templatePath variable should be changed in the post, but I am not sure the correct format for that.
Or perhaps there is a folder where I can manually drop the .xlsx template for it to be found?
Please advise.
jswickJ9PWC
Put the template in the same local folder as the setup sheet .cps
For example: username/AppData/Roaming/Autodesk/Fusion 3060 Cam/Posts is where mine is.
I just moved things around yesterday on my computer and had to find things so I know it works with the new dialogue.
jonathanBUCVS
@jswickJ9PWC  excellent, thank you!
Im guessing there is no similar solution for the cloud folder?
viacheslav.shapilov
Alternative solution can be "linked folder" in the post library.
If you already have some folder with posts on your machine (or network) you can link this folder in the post library without importing posts into Fusion managed locations:
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
jeff.pek
Can you not upload the .xlsx alongside the .cps in the CAMPosts folder in the Assets project? As far as I'm aware, that should get synched into the same place that the .cps does.
Jeff
jonathanBUCVS
@viacheslav.shapilov  This is our current configuration, so I will probably do this. I never occured to me to right click on the Linked tab.
@jeff.pekfrom Import on the Post Library dialogue, only Post Configuration files are allowed, which was the method I was trying. I did not try uploading to Assets
