Error while Programming
Please have a look in the attached Image, i am using a 2D contour strategy to mill these Dia.1 mm holes using a 0.5 mm end mill cutter, there are 24 holes to be machined, when i generate the tool path not all the holes are machined a few are omitted, when i click the yellow triangle in the process tree it pops up with the message (please see the attached image). could someone please let me know the reason and to rectify it.
Regards
Greg
daniel_lyall
your lead in and outs need adjusted it's on the linking tab, holes that big I would just turn the leads off and just make sure the ramping is set correctly
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Hi
Thanks for your feed back, the problem is solved , but i still don't know, how it got corrected , the only change i did was i shifted the center distance of the holes to be machined by 0.1mm, i am still baffled and  trying to find out the reason when time permits.
Regards
Greg
