Error post processing with Fanuc turning
irex6SSS6
irex6SSS6
I'm having an issue with the Fanuc post processor for a turning operation. If my tool is set to any tool orientation other than 0 deg (either in tool setup or in the rouging operation), I get the error below. The code generates perfectly fine if the angle is set to 0 deg.
I'm pretty new to CNC turning, so this could be something obvious but I'm at a loss.
Link to project: https://a360.co/2LOSY2F
Thanks!
Information: Configuration: FANUC Turning
Information: Vendor: Fanuc
Information: Posting intermediate data to '/Users/isaac/Fusion 360 CAM/nc/1001.nc'
Error: Failed to post process. See below for details.
Start time: Sun Dec 20 03:17:19 2020
Loading locale from '/Users/isaac/Library/Application Support/Autodesk/webdeploy/production/380d70885f263236bcd663557495fe325106a36d/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.en.lang'
Post processor engine: 4.5729.0
Configuration path: /Users/isaac/Library/Application Support/Autodesk/webdeploy/production/380d70885f263236bcd663557495fe325106a36d/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc turning.cps
Include paths: /Users/isaac/Library/Application Support/Autodesk/webdeploy/production/380d70885f263236bcd663557495fe325106a36d/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts
Configuration modification date: Sat Dec 12 01:36:04 2020
Output path: /Users/isaac/Fusion 360 CAM/nc/1001.nc
Checksum of intermediate NC data: ada694823674a53fe8c0581d76980756
Checksum of configuration: 4b72a3a97ccd7269ab488394f646ccbd
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9512
Error: Bad axis specified for writeRetract().
Error at line: 1814
Error in operation: 'Profile Roughing1'
Failed while processing onSection() for record 441.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Sun Dec 20 03:17:19 2020
Post processing failed.
fr33l0ad3r
Toggle safe retracts in post processor properties to whatever desirable
irex6SSS6
Changing "Safe retract method" to exactly one axis fixes it. Thank you!
