Error on Parallel 3D toolpath only when using Avoid Surface
Feature flags: contour2D-select-faces machine-builder machine-simulation setup-sheet-configurations setup-sheet-viewer strategy-blend
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\user1\AppData\Local\Temp\Fusion360CAM\1\operation139.ironjob
Debug: Writing jobfile to C:\Users\user1\AppData\Local\Temp\Fusion360CAM\1\operation139.hsm-job
Debug: Using CAM kernel from: C:\Users\user1\AppData\Local\Autodesk\webdeploy\production\04e9fb6ccd573a82d847bb3bb69870b092498b0e\Applications\CAM360\camkernel.exe
Error: An unhandled exception occured 0xc0000005.
Error state stored at 'C:\Users\user1\AppData\Local\Temp\camkernel\camkernel-5532.dmp'.
Debug: Autodesk dcamcomponents 1.95.0 pm12672
Autodesk CAM Kernel 3.27.0 (b9e328b7) x64 STABLE vs2017 b9e328b76abf36520fda73d1b6c51d176a52d656 2021/06/03 02:00
Debug: Total processing time: 171 ms
Debug: Total elapsed time: 263 ms
Invalidated: Generation failed
Any idea on how to fix this? The error appeared after an update sometime this year. I was updating feed height on the tool when the error arose.
seth.madore
Could you export and share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
