Error: Internal error - invalid diameter.
programming2C78B
Advisor Advisor
programming2C78B
Bore cycle on a .197 hole with .156 EM - works fine on the other op, as well as the other part with the same features. Only after updating my subassemblies (fixtures from the other "identical" part) did this come up.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
Hmm. Working for me in this sample test file. Any chance you can privately share your file? Drop me a DM with the A360 link and I'll see what's going on and log this if needed.
Seth Madore
programming2C78B
Seth, I DMd you about it through this forum. Fusion is also throwing out a new error when I try to hit share! I sent screens
