Error: Internal CAM kernel error. Please report through your support channel.
kastrup2
Message 1 of 25
kastrup2
Enabled feature flags: adaptive-turn-roughing bottom-up-pattern-unfolding configurable-tolerance-colors enable-rest-shadow hig-styled-qt import-macro-results live-machine-connection mesh-check-safety milling-continue-rest-machining old-turning-profile-strategy online-system-library post-processing-with-nc-programs restrict-to-4-axis setup-sheet-configurations setup-sheet-viewer spun-profile-v2 strategy-blend tool-library-v4-release toolpath-deleting upload-nc-code
Invalidated: Generation failed
Debug: This operation depends on operation Setup3.
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\Thoma\AppData\Local\Temp\Fusion360CAM\3\operation8.ironjob
Debug: Writing jobfile to C:\Users\Thoma\AppData\Local\Temp\Fusion360CAM\3\operation8.hsm-job
Debug: Using CAM kernel from: C:\Users\Thoma\AppData\Local\Autodesk\webdeploy\production\644cb3fb363c9e2881e69c03ab808028604773bd\Applications\CAM360\camkernel.exe
Debug: Autodesk CAM Kernel 3.6.1 (6b8a5a00) x64 STABLE vs2017 6b8a5a001bae5ac4d0f40db9ac148f39dec8ed9b 2021/01/06 18:00
File "operation8.ironjob", line 28
SyntaxError: Non-UTF-8 code starting with '\x99' in file operation8.ironjob on line 28, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Debug: Total processing time: 93 ms
Debug: Total elapsed time: 172 ms
Replies (24)
Message 2 of 25
JosefVo
I´m getting the same error after todays update.
Tried a bunch of things and this is what I found:
Only Drilling and circular milling calculates properly without error.
All other toolpaths I have tested (didn´t test every single one but most) fail with the kernel error.
I have also opened older files with toolpaths that worked some days ago. If I just hit the recalculate button the remain good. If I for example take a contour toolpath and deselect the contour and select the same one again and calculate it fails also.
Please get this fixed asap as I can´t program and run any parts as of now!
Message 3 of 25
Richard.stubley
Hi Both,
I apologise for this issue, we believe it is due to special characters in tool descriptions. Can you see if removing special characters out of your tool description allows the toolpaths to be calculated.
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 4 of 25
kastrup2
Yes it solves the problem
Message 5 of 25
We have exactly the same problem nearly all of our tools in tool library  have a special character for diameter Ø this do not work.
Tried to solve the problem for several hours and could not generate any toolpaths with some tools.
This is not good as this always worked before.
Message 6 of 25
Richard.stubley
Hi @Anonymous,
Does removing the characters from the toolpath description fix the toolpath generation issue?
I am by no means expressing this as a solution, but I want to make sure that we know the issue at its full extent.  I'd hate for us to fix the issue, only to find there were other scenarios we had not anticipated.
Richard Stubley
Message 7 of 25
Richard
I removed all special characters except for / sign
Example:
Flat end mill Dia 8 L26/26
Description before change:
Flat end mill Ø8 L26/26
We have been using the Ø in the description for about a year.
Some time ago the ° Stoped working like description Chamfer 45°, but i remembered that there was a corrupted
description when we used the ° Sign.
/Lars
Message 8 of 25
Adding to last post,
Removal off the special characters fixed the problem.
/Lars
Message 9 of 25
Polywerk-B
Yes, renaming the tool-description seems to do the trick.
I also had the "Ø"- symbol with into my descriptions.
Curiously it only effected the 2D-Kontur feature and not the drilling function as far as I tested it.
Message 10 of 25
Yes we had the same problem contour was affected by this error.
/Lars
Message 11 of 25
Richard.stubley
The CAM Kernel error should now be solved, the update has gone live, the build number is 2.0.9642
You should not have to remove any special characters now.
Pleas let us know if you are still experiencing the issue.
Richard Stubley
Message 12 of 25
I am still getting this error after the update. I have tried to rename the tool but my 3/16 endmill still has the special character in front of it.
Message 13 of 25
Richard.stubley
Hi @Anonymous,
Are you able to attach your project for me to look at?
Or DM it to me?
Also could you take a screen shot of your "about page"
Click on the "?" in the top right then "about".
It will look like this.
Richard Stubley
Message 14 of 25
Thank you for the help but it turns out that I made an error with my "bottom height". once I fixed that the Kernel error went away.
Message 15 of 25
Richard.stubley
Hi @Anonymous,
Glad to hear you have it sorted.
Are you able to share the project that errors or explain the steps so I can re-create.
We are trying to improve the error messages and this sound like an ideal case.
Richard Stubley
Message 16 of 25
Hi
This file is a simple contour that if no depth is inserted reports an internal kernel error. If the depth is selected like Stock top -0,1 the error goes away.
This can be really confusing when a non experienced operator tries to CAM a DX file = no model depth.
Error message:
Enabled feature flags: online-system-library setup-sheet-viewer tool-library-v4-release
See attached example.
/Lars
Message 17 of 25
grommedia
Observer
Observer
Exactly 1 year later, they messed up with updates again and this problem is relevant. Nothing works. The old ones work, but the new ones don't. When is the update?
Message 18 of 25
jeff.pek
Can you clarify the problem you're having? The issue with the characters was fixed a long time back.
  Jeff
Message 19 of 25
jimN28J2
Observer
Observer
I am also having this problem. and cannot remove the special character from the tool. even if i create a new tool, the software puts the character there on its own.
Message 20 of 25
seth.madore
What special character? Can you provide a clear step-by-step explanation of what you are doing and what the result is?
Seth Madore
