- Mute
- Permalink
- Report
Enabled feature flags: adaptive-turn-roughing bottom-up-pattern-unfolding configurable-tolerance-colors enable-rest-shadow hig-styled-qt import-macro-results live-machine-connection mesh-check-safety milling-continue-rest-machining old-turning-profile-strategy online-system-library post-processing-with-nc-programs restrict-to-4-axis setup-sheet-configurations setup-sheet-viewer spun-profile-v2 strategy-blend tool-library-v4-release toolpath-deleting upload-nc-code
Invalidated: Generation failed
Error: Internal CAM kernel error. Please report through your support channel.
Debug: This operation depends on operation Setup3.
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\Thoma\AppData\Local\Temp\Fusion360CAM\3\operation8.ironjob
Debug: Writing jobfile to C:\Users\Thoma\AppData\Local\Temp\Fusion360CAM\3\operation8.hsm-job
Debug: Using CAM kernel from: C:\Users\Thoma\AppData\Local\Autodesk\webdeploy\production\644cb3fb363c9e2881e69c03ab808028604773bd\Applications\CAM360\camkernel.exe
Debug: Autodesk CAM Kernel 3.6.1 (6b8a5a00) x64 STABLE vs2017 6b8a5a001bae5ac4d0f40db9ac148f39dec8ed9b 2021/01/06 18:00
File "operation8.ironjob", line 28
SyntaxError: Non-UTF-8 code starting with '\x99' in file operation8.ironjob on line 28, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Debug: Total processing time: 93 ms
Debug: Total elapsed time: 172 ms
