Erratic Federates - How to adjust
jeph00
jeph00
Good day folks.
If you look at the screenshot, you will see that I am getting high federates in the lead out/in, even though I have it set to .006. How do I adjust this?
Part also attached.
pludikar
Hi @jeph00 ,
What post processor are you using?  I just tried your model with a Haas and GSK post processors and both gave 0.006 feedrates.  So, I would suspect your post processor - are you able to use another processor?
Regards
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
jeph00
No, I only have access to 1 processor. I will contact out provider, see if its something he can fix.
seth.madore
Access to only one processor?! What is the machine and control?
Seth Madore
jeph00
Seth,
We only have one machine is what I meant, so we use only one post processor in our shop. Machine is a mori with the MSX-850 control.
pludikar
Hi @jeph00
Which post processor are you using?  Just asking the same question I'm pretty sure Seth would be asking - so hopefully getting you an answer from him sooner.
The only relevant post processor that I can find is "DMG Mori NLX Mill/Turn", and that one gives me the appropriate feedrate of 0.006.  The FANUC, APT and CELOS versions can't handle turning.  If you have a custom/machine vendor provided processor, Seth would need to know that too.
Peter
jeph00
Peter,
thanks for the reply.
I found the issue elsewhere in the tool setup page. So - not sure if this is common knowledge or not - but if you look at the screenshot, the value in the Edit Tool window override the values in the Toolpath Setup. So I changed those and I got the proper results.
