Entry Point setting in Linking tab is ignored.
mail.to.chm
mail.to.chm
Hi, I'm pretty new to Fusion 360 so I've just been drawing simple parts to test out on the CNC I have built.
All was going well until the last update (I think) when the ability to set the entry point does not work anymore.
I have attached 2 files 'Test4', which I think was made before the latest update and 'Entry position problem'.
Strangely, I can change the entry point on Test4 but not on the Entry position problem file yet I can't see any difference in the setup of the 2d contours.
I've looked at the other posts on this problem but nothing works for me, or I'm missing something.
I'd really appreciate help on this one, so thanks in advance.
seth.madore
The "entry position problem" file is using "Keep Sharp Corner with Loop" for the Outer Corner Mode, the "test4" file is using "keep sharp corner". I suspect this is a bug (that "keep sharp corner with loop" isn't obeying start point. I'll open a ticket
Seth Madore
mail.to.chm
Fantastic, thank you for posting so quickly, this problem has been driving
me crazy all afternoon.
seth.madore
I've opened up CAM-37287 to investigate this issue
Seth Madore
