Engraving Curve Problem
guilhermeaocosta
guilhermeaocosta
Hi, i am experimenting with engraving on a 3axis CNC i built myself and i am trying different ways to design and program the cuts. today i created a pattern design made of the intersection of circles, kinda like a leaf shape but after applying the Engrave op the cut is not round it leaves a diamond shape on the work instead of a rounded shape.
Any idea what is causing this? on other designs like a rose i did earlier it cuts everything without problem
designdesignresultresult
DanielMolloy
Hi @guilhermeaocosta,
Can you share the file you are working on?
guilhermeaocosta
i actually lost the file cause i forgot to save...
guilhermeaocosta
i can try to make it again and send it, but do you have any idea what might be causing it?
DanielMolloy
No i dont know what it could be based on the image, its always tricky to try and figure these things out from a picture.
If you can reproduce it then i would be happy to take a look at it for you however totally understand if its too much work!
