edite post procesor hurco ending position.
werkplaats2Q7LY
werkplaats2Q7LY
how can i change the ending postion in the new post processor i know it is some where her and i also tried already evrywhere where the 150 valeu stands nothing change somebody hwo can help me.
serge.quiblier
Hi @werkplaats2Q7LY
When you are using a post that is updated, you can search for the function onDefineMachine.
And near the bottom of the function we may have, or we can add a code for defining the home position used by G53/G28 depending on your selection.
Example of this code
function defineMachine() {
  var useTCP = true;
  if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 120], preference:1, tcp:useTCP});
Shortening the code to show the important part
      machineConfiguration.setMultiAxisFeedrate(
        useTCP ? FEED_FPM : getProperty("useDPMFeeds") ? FEED_DPM : FEED_INVERSE_TIME,
        9999.99, // maximum output value for inverse time feed rates
        getProperty("useDPMFeeds") ? DPM_COMBINATION : INVERSE_MINUTES, // INVERSE_MINUTES/INVERSE_SECONDS or DPM_COMBINATION/DPM_STANDARD
        0.5, // tolerance to determine when the DPM feed has changed
        1.0 // ratio of rotary accuracy to linear accuracy for DPM calculations
      setMachineConfiguration(machineConfiguration);
    /* home positions */
    // machineConfiguration.setHomePositionX(toPreciseUnit(0, IN));
    // machineConfiguration.setHomePositionY(toPreciseUnit(0, IN));
    // machineConfiguration.setRetractPlane(toPreciseUnit(0, IN));
// End of machine configuration logic
And we will change it to this one
  var useTCP = true;
    machineConfiguration.setHomePositionX(toPreciseUnit(0, MM));  // ADSK : uncomment the code, and eventually change the value, and set the unit to millimeter
    machineConfiguration.setHomePositionY(toPreciseUnit(0, MM));  // ADSK : uncomment the code, and eventually change the value, and set the unit to millimeter
    machineConfiguration.setRetractPlane(toPreciseUnit(1250, MM));  // ADSK : uncomment the code, and eventually change the value, and set the unit to millimeter
With an older post, with the kinematic defined at the beginning of the onOpen function, then this will be done there.
Cheers.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
