Message 1 of 1
DS30Y C-Axis Index Direction
I'm using a Haas DS30Y to mill hex flats around a diameter with live tooling and the toolpath is patterned around the diameter. The post does not index the C-axis beyond 180 deg, but will instead use negative numbers which causes the machine to rotate in the opposite direction past the flats it has already done. Is there a setting or post modification to allow rotation in the same direction going beyond 180 deg?
