Im trying to create custom acoustic panels and to this end would like to have my cnc machine drill 1mm holes every 3mm, i have been trying to use points for this, the stock size is about 500x500 which means some 30,000 ish holes. no matter how i try and pattern them it just locks up and goes not responsive. When doing the DRILL cam work Ive understood that i can tell it to select same size holes within a boundary which would perfectly suit my needs as i could blanket the whole area with points and then have it select only those within the shape needed, but thats impossible as its just locks up. Ive lowered everything GPU wise etc. Any way to make this possible/work with many points or holes in general? Alot of my projects have what feels like too many parts for fusion to run happily, maybe there is something im missing?
