Drill operation error "Tip offset through bottom"
Benjamin-Schaefer
Message 1 of 8
Benjamin-Schaefer
Good day to all,
I currently have a problem with the bore operation. The error occurs when the selection method is set to Hole diameter. If "Tip offset through bottom" is then also selected, the machining path is extended upwards and not downwards as is actually correct. The error has been present for about 2 weeks now. It can be worked around by setting the selection method to "Surface".
Kind regards, Benjamin
Replies (7)
Message 2 of 8
seth.madore
That's an unexpected result, to say the least. Would you be able to share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
Message 3 of 8
Benjamin-Schaefer
attached is an example where it occurs. Funnily enough, the error does not exist when drilling from the opposite direction.
Message 4 of 8
seth.madore
Okay, it looks like it's related to "Diameter Range" setting, rather than "Selected Faces"
Seth Madore
Message 5 of 8
seth.madore
I've opened up CAM-34671 to investigate this issue
Seth Madore
Message 6 of 8
Benjamin-Schaefer
Is there actually any news on the bug? Has a solution been found or can it be expected for the next update?
Message 7 of 8
seth.madore
This ticket has been solved internally, you will see proper behavior in the next update or so.
-EDIT- Actually, the fix went out last night, please update your Fusion and let us know if there are still edge cases where this is still occurring.
Seth Madore
Message 8 of 8
Benjamin-Schaefer
It looks like the bug is fixed for me after the last update. Thanks for the edit! If I notice it again in another place, I'll let you know.
