DMS 5-Axis Router, Fagor 8065, G0 #MCS formatting issue
Jason_KellyU5SST
Jason_KellyU5SST
I am having an issue of formatting where my machine does not like having a Z0 command on the same line as MCS. I am at a loss as to where in the post to go to modify it to correct this formatting issue.
Below is what it currently does when I post a program with line N50 being the issue
N10 ; T10  D=0.375 CR=0 - ZMIN=-1 - FLAT END MILL
N15 #MCS OFF
N20 #CS OFF
N25 #RTCP OFF
N30 #HSC OFF
N35 #KIN ID[0]
N40 G70 G80 G90
N45 G17 G40
N50 G0 #MCS Z0
N55 #MCS X0 Y0
N60 #MCS B0. C0.
I can manually edit it to the code below and it runs just fine.
N15 #MCS OFF
N20 #CS OFF
N25 #RTCP OFF
N30 #HSC OFF
N35 #KIN ID[0]
N40 G70 G80 G90
N45 G17 G40
N50 G0
N53 #MCS Z0
N55 #MCS X0 Y0
N60 #MCS B0. C0.
 Thank you in advance.
aju_augustine
Hi @Jason_KellyU5SST ,
You can search for the function writeRetract and replace the line under case "MCS"
Original Code:
    case "MCS":
      writeBlock(gMotionModal.format(0), "#MCS", words); // retract
      break;
Modified Code:
    case "MCS":
      writeBlock(gMotionModal.format(0));
      writeBlock("#MCS", words); // retract
      break;
Aju Augustine
Technology Consultant
Jason_KellyU5SST
That worked! Thanks for the help.
