Hello all,
I am a CAD/CAM/Machining novice, so apologies if this is a blatantly obvious obstacle to overcome!
When trying to generate G-Codes for this particular Bush I receive the below error (entire fail log attached in a .txt)
"Error: Direction is not supported for machine configuration.
Error at line: 1
Error in operation: 'Internal Axial Slot (4)"
I understand from this message, it doesn't like the Trace strategy 'Internal Axial Slot (4)' used to create the slots, in particular the angle of entry used. What I don't know is how to get it to like this 😁 , I can only assume I need to edit something in the post config perhaps? I'm told the machine we have is capable of performing this operation.
I've attached the f3d file and am using the up to date Samsung mill/turn fanuc post, below is a link to the machine we are getting if that helps:
Samsung SL2500BL / SL2500BLM Slant Bed CNC Lathe
If any additional information is required please let me know and I appreciate any help/guidance with this!
Alex
