Different component origin orientations
fabrice_gusto
Observer Observer
fabrice_gusto
Observer
Observer
Hi everyone,
I’m French, so please excuse my English.
I’m using Fusion 360 to prepare parts for CNC machining, and I’ve noticed that some components/assemblies do not use the same origin orientation as others.
For example, several parts share a consistent coordinate-system orientation, while others are rotated differently relative to the global assembly origin.
This is not a problem for design itself, but it becomes confusing in the Manufacture workspace, especially when creating setups and positioning parts on the CNC bed. I would like to use the same workholding/setup logic and the same machining orientation for a series of similar parts.
How to fix it ?
programming2C78B
just joint your components together as they need to be and ignore the part origins. They have no effect on your CAM
Please click "Accept Solution" if what I wrote solved your issue!
Christoph_360
Hi @fabrice_gusto
As @programming2C78B  already mentioned, using joints and constraints.
Maybe this example will help
Christoph
pkomatlapalli
Hi @fabrice_gusto,
Did the suggestions from programming2C78B and Christoph_360 help resolve your issue?
If so, please consider marking the reply that helped as the Accepted Solution. Doing so makes it easier for other community members to find answers to similar questions.
If the issue is still unresolved, please provide an update, and the community will be happy to continue assisting you.
Pavan Kumar | Community Manager
