Depth of Cut
Depth of Cut
Depth of Cut
I plan to use 2D Contours to cut 34" Baltic Birch plywood. I plan to use 3/8" compression bit. I wonder if I need to set the Multiple Depths & Maximum Roughing Stepdown value and if so to what value? Or can I cut it in one pass?
Thx
Eitan Barazani
daniel_lyall
That depends on the machine.
What is it?
What Hp is it?
What brand off-cutter?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
It is a Chinese cNC Routher, 4.7KW HSD, Vortex bit.
I wonder from the point of view of the Spindle and the bit.
Thx
daniel_lyall
The best thing to do is just try different depths of cut, start from 1/4 of the flute length and go from there.
Daniel Lyall
The Big Boss
Mach3 User
I usually use 1/2 the diameter of bit. I did try higher value and it did cut. Not sure where is the point where one would say this is too much or too little.
Eitan
daniel_lyall
That's the default safe cutting feed, speed, and depth tool paths like Adaptive you can run it at 100% depth, and depending on the material you can go way over 10% width of cut, you can only know this by trying it.
Daniel Lyall
The Big Boss
Mach3 User
