Hello
Here are some answers to your questions.
Does the general Siemens 840D Post support this Machine type?
Not without modification, as the milling post is only supporting milling toolpaths.
And trying to use a siemens turn mill post will be wrong, see the explanation below.
And the main question, how can I program this in Fusion?
It can be programmed by defining a turn mill setup in Fusion, creating the operations in the same setup.
Their properties will be identified by the post, so that we can generate the gcode correctly.
With the Setup for Milling or Mill-Turn?
As I said the Mill Turn setup.
I thought the Mill-Turn is only for Lathe Turning machines?
Tricky thing, there is 2 sort of these hybrids.
a - The lathe that think it can mill the part. (Mori Seiki, Doosan, Nakamura ....)
Acting by default as a lathe, and needs to be instructed to "switch" to milling mode by command like C axis enable, polar mode activation...
We use a base turning post to support them, adding function to deal with the milling part.
b - the milling machine that think it can turn the part (as the FD, Willemin Macodel, Chiron, some Mazak)
By default this is a milling machine, we can instruct the machine to "switch" to turning mode by a Cycle command.
In this case, we start with a milling post, adding logic to activate the turning mode when needed.
And how is it possible to create a machine model for the simulation?
The simulation can be created by the Machine Builder module in Fusion, but you need to get the 3d machine model from the customer.
In the current state of the machine simulation, you won’t be able to simulate turning toolpath, only the milling ones.
Cheers,
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
