CYCLE_REVERSAL Action Command Not Working in HAAS NGC Post
ChevelleNV
ChevelleNV
I am using the "HAAS - Next Generation Control" Post and trying to add the "CYCLE_REVERSAL" Manual NC "Action" to clear chips on our drilling cycles the MANUAL NC command added both before or after a drilling cycle seems to not affect the outputted code is there step I am missing to make this work?
a.laasW8M6T
Hi
This possibly doesn't work with the Chipbreaking cycle, possibly to do with the accumulated pecking depth.
If the accumulated pecking depth is less than the hole depth the post puts out the code as an expanded cycle.
If you make it more than the hole depth it outputs G73 with the E2000 for cycle reversal as expected
(Drill1)
N25 T1068 M6
N30 S4280 M3
N35 G17 G90 G94
N40 G54
N45 M8
N50 G1 X0. Y0. F5000.
N55 G0 G43 Z19.5 H1068
N60 G0 Z9.5
N65 G98 G73 X0. Y0. Z-44.043 R5. Q1.7 E2000 F436.59
N70 G80
N75 G0 Z19.5
Should work fine using the Deep drilling full retract too.
ChevelleNV
I need it with pecking since we are doing lights out machining and I don't want to risk breaking drills. I will hand write my code
a.laasW8M6T
Hi
Deep drilling full retract is still pecking, its just maybe not as fast as the Chip breaking cycle which doesn't do a full retract out of the hole until the accumulated peck depth
