I am having a hard time figuring out exactly how to do this in Fusion. I have a custom tool made that is the same geometry as the spline on this hub, and I need to program it to be able to work on a Y axis mill/turn Lathe.
I have attached the file that is the closest I have gotten on it, I dont know if I need to draw additional geometry to pick up the correct point or what needs to happen here.
The custom tool should be in the toolpath that I left in the attached .F3D file.
I was planning to use a circular pattern of the tool path in order to cut the rest of the teeth, but I dont know if there is a better way to do that as well.
Thanks in advance.
