Cutting serrated edges on an angle
CuttingEdgeManufacturing
Hello all, I'm looking for a toolpath that can help me out with this part. basically serrated edges radially about a round part. some straight, some on a taper. i have 4th axis capabilities. initially we thought just use a chamfer tool but im having issues getting f360 to let me do much with the chamfer tool because its not a endmill.
i also know that the chamfer would over/undercut when cutting on the angle. this is ok depending on how much it is overcutting.
anyone have any pointers?
seth.madore
Give this file a try
Result:
The unhandled error is due to the tip diameter being set to zero. Set it to a small value and it will generate fine.
Oh, and what's going on with the root of the top serrations?
Seth Madore
no idea i didnt draw it ill bring it up with our engineer. good catch.
ill give the file a shot. thank you
seth.madore
It's because of your Pattern. The designer actually has them doubling up on itself.
Seth Madore
they are .5 degree serrations and he did 720 for the full 360 degrees. so that checks out. i changed the computing option for the pattern to optimized and it looks much better.
