Cutting On a Contour Line
jburickJUFQ4
jburickJUFQ4
Hello there!  This feels like it should be a simple solution but for the life of me I am having a hard time figuring out how to cut on a 2D contour line - I know how to cut inside or outside of the contour line by clicking the red arrow, but I have a situation where I would like to cut directly on it.  Thank you!
jburickJUFQ4
I'm assuming it would be adjusting "stock to leave?"
engineguy
@jburickJUFQ4
Under the "Passes" Tab in your 2D Contour go to the "Compensation Type" and set it to "Off", toolpath will then be on the selected edge/line etc, hope this helps 🙂 🙂
Or you could try using the "Trace" toolpath, it gives you Left/Center/Right Options for cutting, downside if you need "Tabs" then it doesn`t have them.
jburickJUFQ4
Thank you!
