cutting internal helical slots in a bush
Hello! Can anyone help? I am trying to set up the creation of a bush and need to mill/turn some internal slots. (see attached model) Currently the (lollipop) tool / toolholder traces along the path and fails by colliding with the stock. I think ideally what I want to happen is for the tool to come in at an angle and drop down to the first touch point. Inner/lower. I really want the tool to move in the y & z axis, NOT the x axis. I want the cutter to spin and I want the chuck to rotate in order to cut the internal spirals. Can someone please help me? Happy new year guys
You cannot use tool orientation as tool approach angle, it is used to index A or C axis, mill features on side of the part or to tilt  Z axis.
Your tool is crashing because shaft has no clearance when tool is at full depth in slot.
2020-01-01 16_41_53-Autodesk Fusion 360.png2020-01-01 16_40_49-Autodesk Fusion 360.png
I used .0001 shaft diameter to get tool path then scaled it down to be in line with shaft of 3/4" slot mill.
In picture below, red is showing 3 mm tool and tool path at center of shaft.
Magenta is showing scaled tool path and 3/4" slot mill with tool path on its center and tool edge matching 3 mm tool in top view.
I couldn't offset drive curve from your modeled spiral so i scaled tool path instead.
The other way is to construct spiral at diameter required by slot mill and regenerate tool path directly off of it.
Judging from what I have done before, attached code should work but test in front of part before making chips.
Here is the link to tool i would use
http://www.harveytool.com/ToolTechInfo.aspx?ToolNumber=965459
2020-01-01 16_12_58-www.harveytool.com_ToolTechInfo.aspx_ToolNumber=965459.png
daniel_lyall
Silly question but is this for a lathe with live tools or a mill and 4th axis?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
daniel_lyall
I have seen it done with a mill doing mill turn.
Daniel Lyall
The Big Boss
Mach3 User
Thank you for the reply, I will look in this. Happy new year
In my G-code file, you need to replace G and M codes with ones that your mill-turn is using.
In Haas world ....
G15 is main spindle selection
M154 - C axis on
M155 - C axis off
M133 - rotary tool on CW
M135 - rotary off
M15 - brake off
G112 / G113 same as G12.1 / G13.1 in Fanuc, polar mode on / off
I start nw year with Hyundai Wia HD2600Y, nightmare with indicating rotary tools on Haas is over with.
I will, however, suffer from PHTSD (Post Haas Traumatic Syndrome Disorder) for some time to come because I have to adopt programs to new controller as I run repeat work, ....... but new year should be happier then old despite that.
