Cutter compensation, Fanuc controller tools offset in radius
schouten323
Message 1 of 12
schouten323
What is the solution for the following situation.
Fanuc controller tool offset is set in radius.
Post processor Fanuc milling, generic.
Description: When executing the NC tool is away (far away) from the part.
Replies (11)
Message 2 of 12
seth.madore
How far away is the tool from the part? Do you have any images or files you can share that give us more information as to what is occurring?
Seth Madore
Message 3 of 12
schouten323
Below file link:
https://a360.co/3BnwEaq
and the  NC.
Mesage on controller is INTERFERENCE in G41/G42
Message 4 of 12
seth.madore
The file you shared has no Setups or toolpaths associated with it. Please save your file and share again.
My first suggestion (without seeing the file with toolpaths applied) is to set your Minimum Cutting Radius to zero, but insure that your Compensation Radius Allowance is a non-zero (and positive) value.
Seth Madore
Message 5 of 12
schouten323
Message 6 of 12
seth.madore
Hmm, still not seeing the toolpaths 😕
Seth Madore
Message 7 of 12
schouten323
the toopath is Setup 2/Circular3(3)(FREES-10MM)
Message 8 of 12
seth.madore
Here's what I see when I open the latest file you shared:
Would you be able to share the actual Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 9 of 12
schouten323
Attached files.
Message 10 of 12
seth.madore
Ok, that's helpful, thanks. As you're using the Circular toolpath, there are less options exposed to users than what the 2D Contour toolpath would have.
You're using "Wear" compensation, so there really shouldn't be a problem here. Can you confirm that you have zero data in the radius/diameter offset for T16?
Seth Madore
Message 11 of 12
weber_dominic
If you wanna use Radius, you should use Compensation Type "In control"
Message 12 of 12
schouten323
Thanks for advice. Is working with In Control.
