Cutter Comp Issue on Dovetail Cutter with corner radius
I am using a 8 mm, 7 degree dovetail cutter with a 0.5mm rad on the corner to machine these pockets, but I am having some trouble with the cam.
When I select the edge of the pocket as below, the simulation seems to gouge into the part. I can correct this by modeling the 0.5mm radius in the corner and selecting the inside edge but once on the machine the cutter comp is surely going to make this incorrect?
I am yet to run this yet but is just a simulation issue and my original choice of contour will work correctly? Or am I doing something wrong here? (I probably am!) Maybe something to do with the theoretical endpoint of the cutter and how its trying to account for that?
Any help would much appreciated!
