Crash, might be related to Trim toolpath.
HughesTooling
Consultant Consultant
HughesTooling
I created a copy of a setup containing a trimmed toolpath. In the copy setup the op was duplicated so that setup had 2 identical ops. I tried to delete one and Fusion crashed. error report CER_207033793
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
A bit more info. Opened the recovered design and deleted the top one of the 2 copies. Edited the remaining op and select new faces and drive curves, hit OK but the original op in the other setup regenerates not the one I edited so it seems like the blend with the timed tool path is linked to the source it was copied from. Also note in the image below the Z is pointing the wrong way. The setup and all other ops the z is pointing up.
Mark
Mark Hughes
HughesTooling
Here's a screencast showing that editing the op in the lower setup make the op in the upper setup regen. In the end I had to delete the folder and recreate, trying to delete the op I edit in the screencast made Fusion crash!
Mark
Mark Hughes
seth.madore
Just so you don't feel like you're talking to yourself here...
The dev's are aware of this thread and will likely be discussing the issue amongst themselves. I know I need to make up a bug report of this, but I'm so far behind in Liberty Machine work it's not even funny anymore....
Seth Madore
