convert g92 to g76 thread cycle
simonswb6
simonswb6
The current post processor i have is for a funuc control and for a threading cycle, it using a g92. My machine (mazak) does not use g92, but instead uses a g76.
i have the post process outputing the code correctly, however it keeps repeating. its calling the onCyclePoint until it reaches the min x value. anyway to stop this? i just need this line once...
N23 G76 X2.617 Z-0.435 K0.04 D4 F15.999999999999998
N24 G76 X2.609 Z-0.435 K0.04 D4 F15.999999999999998
N25 G76 X2.601 Z-0.435 K0.04 D4 F15.999999999999998
N26 G76 X2.593 Z-0.435 K0.04 D4 F15.999999999999998
switch (cycleType)
case "thread-turning":
var minDepthCut = Math.ceil(getParameter("operation:threadDepth")*1000/(getParameter("operation:numberOfStepdowns")));
var threadPass = getParameter("operation:threadDepth") / 100;
var inverted = (toolingData.toolPost == REAR) ? 1 : -1;
//var r = -cycle.incrementalX * inverted; // positive if taper goes down - delta radius
var threadsPerInch = 1.0/cycle.pitch; // per mm for metric
//var f = 1/threadsPerInch;
xOutput.reset(); // at least one axis is required
zOutput.reset();
writeBlock(
gFormat.format(76),
xOutput.format(x),
zOutput.format(z),
"K" + getParameter("operation:threadDepth"),
"D" + minDepthCut,
"F" + getParameter("operation:threadPitch")
// break;
//debug("The value of x is " + x);
return;
boopathi.sivakumar
@simonswb6
I think you are using the modified post could you please attach the post you are using
Boopathi Sivakumar
Senior Technology Consultant
simonswb6
there maybe better solutions, but this worked...  there is a method called isLastCyclePoint()...
     // writeBlock(formatComment('made it'));
    var iThreadDepth = getParameter("operation:threadDepth");
    var iPasses = getParameter("operation:numberOfStepdowns");
    var iDepthOfCut = iThreadDepth/iPasses
    var threadsPerInch = 1.0/cycle.pitch// per mm for metric
    var useCycle = getParameter("operation:useCycle");
    if (isLastCyclePoint() && useCycle
      writeBlock(formatComment(' x - bottom dia'));
      writeBlock(formatComment('z  - end point'));
      writeBlock(formatComment('a -  tool tip dia'));
      writeBlock(formatComment('F - thead lead'));
      writeBlock(formatComment('k - thread height'));
      writeBlock(formatComment('D = depth of cut'));
    zOutput.reset();
    writeBlock(
      gFormat.format(76),
      xOutput.format(x),
       zOutput.format(z),
      "D" + iDepthOfCut,
      "F" + threadsPerInch.toFixed(4)
     // break;
      return;
Which Line do i replace those codes above with? for some reason it keeps failing and saying post processor failed.
