Confused origin coordinates
Hi
I just made a model in fusion 360. In defining the stock I placed the origin in plan view on the bottom left corner of the model. The x across the bottom side the y up the left side.
When it came to actually making the piece I had to turn the stock 180 degrees on the cutting bed. So I guessed the origin point would now have to be on the top right.
I used a probe on that corner to give a zxy 0.
My machine acted as if it were cutting from the bottom left and began cutting air behind and to the right of my stock.
I am no expert but I assumed the origin point was only established when the machine was zeroed and that the xy coordinates told the machine which direction to head. Am I wrong to assume this 🙄? I know I have done something really dumb but can someone put me right.
Please feel free to laugh.
JSR
TheCADWhisperer
seth.madore
When setting the Setup WCS, it is best to select the option for "Select Z and X axis". You will then first select a face that is perpindicular with the Z axis (typically the top face of the part) and an edge that is inline with the X axis. This will "snap" the WCS orientation to one that will represent what you are going to see at the machine
Seth Madore
