Closing without saving?
How do I set up Fusion to not automatically save when closing a tab? Sometimes I have a CAM setup that is running well on the machine, but I want to play "what if" and evaluate different tools, operations, etc in Fusions CAM workspace. Since the existing job is running fine, I don't want to overwrite it and lose the "working" setup while playing around. I know the easy answer is to copy the file and mess around with the copy, but sometimes I forget to do this, and start messing with my "good" file. In other programs, I can just close the tab/window, and a pop-up dialog box will ask if I want to save my changes or discard them. Fusion sems to be a little rude here, and just saves the new data without asking.
dave.anderson
In the Preferences > General >, there's a check box for 'Automatic Version on Close'. If this is disabled, you will not get the version.
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
Hunh! Looked right past it. Thanks!
