CL-1 post, have to turn off "safe start all operations" every time
EccentricEngineer
EccentricEngineer
All my other post processors, if I turn on "safe start all operations" it stays on for that post until I turn it off, then it stays off.
I turned it on once for my Haas CL-1 by mistake (the safe start code crashes the machine), and now it's permanently on and I have to manually turn it off every single time I post code.
As far as I can tell, it's turned off in the post itself, although I'm no expert with posts so maybe there's something else I'm missing. I've restarted Fusion but the same problem persists.
Any help would be appreciated!
programming2C78B
its on because you have it checkmarked! The post window overrides whatever the actual post processor text file itself says.
Please click "Accept Solution" if what I wrote solved your issue!
viacheslav.shapilov
Fusion remembers last used post properties and uses them when you post NC code.
You should be able to uncheck it and post, and this state also should be remembered.
We had an issue, when property set to default was not remembered in January release. But it was fixed in a week after release.
Could you please check, if you are on the latest Fusion version?
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
EccentricEngineer
As mentioned in my original concern:
I turn it off before I post, then when I go to post again, it's back on again. I have to manually uncheck it every time
EccentricEngineer
Updated to the latest version. This seems to have fixed the issue.
Thanks!
