Channel 1 block  N24361  Illegal end of file.
musabismail32
musabismail32
I have been selected  post  siemens SINUMERIK 802D in Fusion 360 software
but the CNC which I using is SINUMERIK 828D BASIC.
After doing simulation successfully in fusion 360 and get NCprogram
In cnc it give me message
  1. Channel 1 block  N24361  Illegal end of file.
I don't what I have to do
  • Please provide me some solution
.CNC which I'm  using.jpgphoto (Channel 1 Block N24361 illegal end of file).jpg
DarthBane55
If you attach your g-code file in here it would definitely help... right now we have nothing to look at.  You might be missing a M30, or a "%" or a million other things.  Knowing the controller that's on your machine will help too.
musabismail32
I attached  the code
engineguy
@musabismail32
@DarthBane55
This appears to be a Seimens Control setting of it`s "software limit switches", the actual line of code being referred to is in the middle of the program so not an ending character.
Not a Fusion issue so not able to help much I am afraid 😞
See below for what I found for that Seimens error.
Sinumerik Alarm 10621 Channel %1 axis %2 rests on software limit switch %3
Parameters:
%1 = Channel number
%2 = Axis name, spindle number
%3 = String
Definitions:
The specified axis is already stationary at the displayed software limit.
Reactions:
– Alarm display.
Remedy:
Please inform the authorized personnel/service department. Machine data 36110 POS_LIMIT_PLUS/36130 POS_LIMIT_PLUS2 and 36100 POS_LIMIT_MINUS/36120 POS_LIMIT_MINUS2 must be checked for the software limit switches. Shut down in JOG mode from the software limit switch. Please inform the authorized personnel/service department.
Machine data:
Check the axis-specific interface signals: “2nd software limit switch plus” (DB 31 – 61, DBX 12.3) or “2nd software limit switch minus” (DB 31 – 61, DBX 12.2) check whether the 2nd software limit switch is selected.
Program Continuation:
Alarm display showing cause of alarm disappears. No further operator action
References
  1. Siemens Diagnostics Guide by Siemens
